Question about Kyocera Mita Office Equipment & Supplies
My taskalfa 5550ci screen is off but the motors will turn and warm but no display
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
/uploads/images/copystar-c2300-error-code-34884244-4-1.jpg
Dec 11, 2014 | Copystar Office Equipment & Supplies
System error
Needs firmware update
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Aug 14, 2014 | Kyocera Mita Office Equipment & Supplies
ADD TONER ERROR
Good day, if your error is toner then make sure the small white gears on the back of the toner cartridge is turning, if they are not then replace toner bottle, if they are turning ask a technician to test the toner motor. If your machine displays error C6400 then enter service mode by pressing 10871087, now press 163 and OK, now restart your machine, if the code is still there then you should replace your fuser/fixing unit.
Apr 03, 2014 | Kyocera TASKalfa 180 Copier
Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
Oct 30, 2012 | Office Equipment & Supplies
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
On the display it says call service c6000 and how to correct this error massage?
Hi
Error C6000 means Broken fixing heater wire. In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s. To resolve this try this reset procedure--
Turn off the copier by opening the top toner cover. Turn copier on, when you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Now scroll down to "maint mode", press "enter" then enter 163 press" enter " turn off copier then turn back on.
If this doesn't resolve your issue then you'll need to check whether heater M or S is installed correctly. If it is installed correctly then make sure that the heater M or S wire is not broken. Hope this helps...
Daniel
Oct 09, 2010 | Kyocera Office Equipment & Supplies
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
62 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
