Question about Science & Laboratory
Who is suppose to put the safety seal on the **** test speciman
    Top Expert:
  • 66,497 Answers
GIVE YOU 1 GUESS IF YOU HAVE TO ASK HERE IT IS NOT YOU
Posted on Mar 02, 2019
Why is there oil leaking - or being pushed out - around my oil filter housing seal?
There used to be a copper ring as a gasket between the oil filter and the motor. Look if you forgot to put one there. (copper ring)
Supposed to be a new one with every filter.
Jul 12, 2014 | 1981 Yamaha XJ 650
I put a axel seal in my chevy lumina and the seal.is thos leaking what im I supposed to do?
check the axle it self for a grove that was made by the old seal. if it does have one replace the axle.
Apr 07, 2012 | 1995 Chevrolet Lumina
Hi,My pressure cooker is not giving whistles.It is happening since two days.It had worked properly for the past 1 year.Safety valve is gud.I cleaned the pressure nozzle.There is not obstruction in pressure...
Maybe the whistle wore out! Who knows? Important thing is that it pressurizes and cooks rapidly like it is supposed to. Or if you are not developing as much pressure because the lid is not on tight enough, that could account for it. Make sure the top is on really tight for best seal.
Sep 20, 2017 | Kitchen Appliances - Others
Were able to fill the a/c with freon but it would run out in a day or two. Tried putting stop seal in it, but the freon cylinder wouldn't puncture, so we could not put freon in right away like it...
The system at this point is shot. The dryer is contaminated with oil and will not function correctly even if the leak were sealed. The system will have to be evacuated , flushed and leak tested, repaired and recharged.
Oct 04, 2017 | 1998 Ford Mustang
When pulling coffee by opening valve, water leaks from spindle. Safety valve is leaking?
in the system you have 2 safety valves. one for tank other for coffee boiler. the coffee boiler safety valve should be set at 12 bar. if safety valve of boiler is leaking try resetting or changing rubber than setting.
ps: do not touch the tank safety valve, only change it with new, tested and sealed one.
Feb 09, 2011 | La Pavoni CUA001R Cuadra Espresso Machine
Brake fluid is leaking out around my brake pedal
you have a bad break master cylinder seal. replace master cylinder unless you have the expeirence to rebuild master cylinder
Jan 22, 2011 | 1990 Geo Prizm
Piece fell off bottom of door.....white long piece about 24 in long how do I put it back on? JVM 1350 002
would not be happy repairing a microwave door as ( I am an electrical appliance tester ) door seal keeps microwave emissions inside and safe -- Ps microwaves should by health & safety law be tested annually for safety - ie emmision level / earth leakage etc
May 26, 2010 | Microwave Ovens
Superadio noisy volume control
have you tried just cleaning them? even though they are probably supposed to be "sealed", most of them are not. if you purchase a can of pressurized tuner cleaner, radio shack used to carry it. saturate the volume control while turning it. i usually wrap the unit with paper towels as to not get the rest of the board. i also usually put on my safety glasses. you will see why. i am usually surprised as this works well with 90 percent of them i do.
Feb 19, 2008 | GE 35810GC3 (14 Channels) 2-Way Radio
Science & Laboratory Logo
118 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
