What do I check? Nothing turns on...no noise whatsoever!
When plugged in and powered up, the controller (under the motor cover) will have a red LED lit to show the power is on. If it is on, you have a harness or console issue.
Wire harnesses are frequently damaged when machines are assembled or moved, usually at the bottom of the console upright.
If the LED is not on, check the outlet for power, check the power switch, it may be defective, if they are good, replace the controller. Very unusual to have a dead controller in an Icon machine, but it does happen.
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
We just unplugged our sony dvd player and plugged it back in and it worked.
SOURCE: Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
SOURCE: I bought a Gold's Gym 450 Treadmil that won't turn on
You can try to get it from the store where you had purchased it or try to search it online.
SOURCE: I turn my Acer on and nothing happens. The light
Try this it worked for me
Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
Note: These instructions are only for the Acer Aspire One AOA-110 and the AOA-150 netbook series and should not be performed on any other model Acer Aspire One.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
