DONT FIX IT WITH 1-800-532-4187 SPAMMERS
On my printer, one of the cartridges was jammed. You can diagnose if one of your cartridges is the problem by taking out all the cartridges, then add them back into the printer one at a time, rebooting the printer each time. When the error comes up, you have found the cartridge (or motor) that is causing the problem. In my case, it was the cyan cartridge. I was then able to fix the problem by manually rotating the roller on the cyan cartridge. This must have unstuck something because I put it back in and the printer is now functioning normally.
Have you performed a hard reset on the printer?
1. Turn the printer on, if it is not already on.
2. Wait until the printer is idle and silent before you continue.
3. With the printer turned on, disconnect the power cord from the rear of the printer.
4. Unplug the power cord from the wall outlet.
5. Wait at least 60 seconds.
6 Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
7. Reconnect the power cord to the rear of the printer.
8. Turn on the printer, if it does not automatically turn on.
9. Wait until the printer is idle and silent before you proceed.
Try to print. If the issue persists, it would confirm that the product has experienced an error with the fuser unit,
And requires a repair or replacement.
SOURCE: hp color LaserJet cp2025 59.c0 error how to fix it
59 errors indicate one of the motors have failed. It could be a bad motor but also a bad cartridge will overload a motor and cause the error as well. If you have spare cartridges, try changing them one at a time and restart between changes to see if the error goes away. Also if the error only happens when you start to print it might be the fuser motor.
SOURCE: LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
i have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
Thank you so much for giving this insightful detail. It will really help me a lot to fix my printer issue. I would like to tell you that our company is also having a more information about how we can solve this HP printer errors 59.f0 Issue. For more information please visit our blog link below.
https://goerrors.com/printers/hp-printer...
