Cell Phones Logo
A
Anonymous Posted on Mar 02, 2019
How do I remove Launcher from my A73 Oppo - Cell Phones
Carlo Barzo
Level 3:
  • Master 530 Answers
  • Posted on Mar 03, 2019
Carlo Barzo
Master
Level 3:
Answers
530
Questions
0
Helped
128303
Points
1766
  1. Open your device's Settings app .
  2. Tap Apps & notifications.
  3. Tap the launcher to uninstall. If you don't see it, first tap See all apps or App info.
  4. Tap Uninstall.
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 22, 2018
SOURCE: I have a new oppo a73, I have downloaded two apps where are they stored so I can access them.
You access them through the google play store, right click in the upper left corner to open your downloaded apps.
Why doesnt my oppo a73 ring in
HELLO,
IT SIMPLY MEANS THAT YOU HAVE REDUCES THE RINGING VOLUME FROM THE SIDE BUTTON .
YOU CAN SOLVE THE PROBLEM FROM THE SIDE BY INCREASING THE VOLUME BY MAKING USE OF THE UP AND DOWN BUTTON BESIDE THE YOUR PHONE.
OR
FROM THE PHONE RING SETTING.
THANKS.
Hello please do anybody knows how to bypass a password locked Oppo A73?... Please urgent answers needed...
Oppo A73 Unlock by Hard Reset
  1. Power Button + Volume Down Button.
  2. Power Button + Volume Up button.
  3. When you see the Oppo logo appear, release all the Buttons.
  4. After that, Using the Volume Buttons to select Language and press the Power Button to confirm.
Oppo a73 cell phone got wet, is there a achance of reviving it?
Hi
Not all-ways but some times it can, it will have to be opened up and dry with a hair dryer, it some times work, have a go you got nothing to lose.
Good Luck
Jan 09, 2019 • Cell Phones
Jul 22, 2018 • Cell Phones
How do i get my blu 5.5 to stop saying application error it wont let me do anything
This usually happens when moving apps to the SD Card with the stock Launcher (i.e., through the "Manage Aapplications" menu).
1. Remove the battery.
2. Remove the SD card.
3. Reset it to factory.
4. Install Launcher Pro & Launcher Switcher.
5. Reinstall the apps that you had.
6. Use Launcher Pro as your main launcher
Ok I am having trouble with my Android Craig tablet. There's a message keeps popping up on my screen an it's blocking me from getting to my stuff. The message says "The application Launcher (process...
Phone is getting an error message: "Unfortunately Launcher Has Stopped."
Unfortunately Launcher Has Stopped:
  1. Swipe your finger from top to bottom on the screen to view the notification panel
  2. Touch the Settings or
  3. Touch Apps
  4. Touch Menu or
  5. Touch Reset App Preferences
  6. Touch Reset Apps
  7. Swipe from right to left 2-3 times to show the ALL list.
    (For device running on Android 6.0.X touch Menu then Show system)
  8. Touch Launcher
    (For device running on Android 6.0.X touch Stock Android then Storage)
  9. Touch Clear Data
  10. Touch OK
  11. Power Cycle Phone
  12. Test phone
hope this isn't clear as mud. :) and helps you
Hi my tdk wireless a73 boom box only operates when it's plugged into a power outlet. Other words, no longer recharges. What's the problem ? How can I fix it ? Thanks !!
Heres how....
1. remove the battery following this... http://tdkperformance.host4kb.com/article/AA-00394/0/A73-Wireless-Boombox-Battery-replacement-instructions.html
2. try to charge the battery individually even for a minute each, because the battery is totally drain that's why it is not charging.. and if your lucky you can measure a voltage individually. and if it happens return the battery to the unit and continue charging on the unit, indication of red led on the power button means its charging. if u dont measure any voltage on the other batteries means you have to replace the all battery with the same current. more current more hours of usage.
3. original batteries rating is 2000ma 1.2 volts size AA (6 pcs.)
My phone model Micromax A73 cannot download adobe flash player. Why I buy to india please explain at http://www.umnet.com/
Micromax a73 browse net very slow.. m ashme of my fren tat m using an anroid phone bt I oly knos the prblm wit tis cel m ashmd of slf... plzz hlp me ot wch browsr 2 use n 3g nt suportd yet.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
