Freezers Logo
a
andre charette Posted on Mar 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my name is andre i am looking to find parts for my conter top igloo ice machine parts number is ice115ss
Mr.Mike
Level 3:
  • Master 580 Answers
  • Posted on Mar 02, 2019
Mr.Mike
Master
Level 3:
Answers
580
Questions
0
Helped
196018
Points
1906
Hi there, check this out http://igloo.curtisint.com/product-support/
there is no number but you can write the company and request a repair/parts and they should accommodate as for this item is still considered "active" status.
good luck
https://www.6ya.com/mrmmike
Can i leave igloo ice machine when it is full
Yes, it is safe to leave an Igloo ice machine when it is full. However, if you plan to leave the ice in the machine for an extended period, it is recommended to transfer the ice to a freezer to prevent melting and refreezing, which can cause the ice to clump together.
Apr 22, 2018 • Freezers
3helpful
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Apr 29, 2016 • Freezers
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
2helpful
3answers
My portable ice maker is not making ice, when turned on it shows ice full, but there is no ice in it. Any advice?
it seems the sensor is jammed or malfunctioning, fooling the control section and keeping the machine from working.
I don't know the machine but the sensor detecting the full ice section is either mechanical or a thermistor (electronic). Locate the sensor and make sure it is in position to sense or simply messing with it may make it work again.
Igloo may have a troubleshooting section in their website.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
