Question about Symbol Computers & Internet
My bush smart tv connects to wired internet but when I try to connect wirelessly it comes up with a blocked symbol in the top left hand corner and then says its disabled. Can anyone help with this please?
    Habit-Forming:
    New Friend:
  • 60 Answers
Many products are manufactured in where you must chose one or another for Wifi and it kinda makes sense. Your faster connection will be a LAN Wire to your TV and go thru the process of mating them.
If you want to go wireless unplug LAN wire and perform a wireless setup always remembering you to have routers password available either way you do it. You are getting that pop up because the TV is telling you to choose one method as the signal is redundant.
Posted on Mar 02, 2019
  • Bill Jamieson Mar 02, 2019
    Habit-Forming:
    New Friend:
  • 27 Answers
Http://bush-support. com is their support website. Consider resetting the TV to factory specs. Check for firmware & software updates on the website above. Good luck.
  • 553 Answers
Is your router or firewall blocking it? are your setting correct? Sounds like an access problem- there should be an error code or message associated with that exclamation.
good luck
you can also video call mr or over the phone for a direct fast solution https://www.6ya.com/mrmmike
Anonymous
SOURCE:
Anonymous
  • 150 Answers
SOURCE: My laptop won't connect to wireless internet...
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Posted on Nov 15, 2007
Anonymous
  • 59 Answers
SOURCE: Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Posted on Mar 29, 2008
Anonymous
  • 6 Answers
SOURCE: Symbol Pocket PC 2003 ( MC50) wireless connection errror
Just upgrade the software on it to version 21 from Motorola site
Posted on Dec 11, 2008
shaun taylor
  • 1527 Answers
SOURCE: Cant get AV1 symbol off top left hand corner of screen
hello on the remote control theres an button with an i symbol try pressing tv then the i button it should clear it
shaun
Posted on Oct 15, 2009
aurinje
Tom Esterhuizen
  • 181 Answers
SOURCE: i need to disable wap.there
The only way you can really disable it without annoying error messages is to call your network who can apply a product to stop it.
The E doesn't mean you are using the internet, all it means is that there is 'EDGE' capable signal in your area.
Posted on Feb 03, 2011
How can i remove youtube from my childs smart bush tv
most likely . go into smart tv settings look for application setting
go into this and remove youtube application.
However a smart child could use internet browser and www.youtube.com
http://www.mckeay.net/2008/11/26/blocking-youtube-with-a-wrt54g/
You could connect the tv to a router and block tcp port 53
May 06, 2017 | Bush Televison & Video
How to connect tv to internet for netflix
First, I am assuming that you have the internet connected at your house and I am assuming that you have a wireless access point or a router with Ethernet connections on it. If you do not have these, then you cannot connect to the internet. On most smart TV's they have a "settings" or similarly named menu item, where you can connect to your home wireless system. Select this and then scroll down the menu until you fine something that says internet or wireless or even quick setup. From there you just select wireless, type in your access password and it should work. All this will be explained in the owners manual for your smart TV.
Feb 25, 2016 | Magnavox Televison & Video
Why can't I connect to the internet/Netflix/You Tube?
You TV is no longer connected to your Internet access point/wifi sharing device.
Jun 02, 2015 | Bush Televison & Video
Hiw do i connect my tv to the internet? 8ts a bush 40" full hd led smart tv
You really need to read the manual to your TV. You need to have a router connected to a high speed Internet service. If you mean connect to the Internet, your smart TV will,have to have a browser, like Opera to enable you to get online. The smart TV apps are selectable with your remote, but you have to get the connection first. If you don't have high speed Internet and a wireless router it ain't gonna work. I don't have the manual to your set, so I can't tell you the exact steps you use on your remote control.
Jan 24, 2015 | Bush Televison & Video
Bush tv says connected to internet but when i press the button to go online it tells me i am not connected and check setting
This happened to me and finally I got the TV close enough to the router for it to work (guess some built-in WiFi hardware in some TVs is not very good). You could also install a range extender for your WiFi if you don't want to move the TV.
Dec 16, 2017 | Bush Televison & Video
Can I get help with connecting my smart tv to internet as its not working for me thanks a million :)
Hi, commonly these TVs use a network cable for connecting to Internet through a router, another TVs are wireless enabled, in this case you need a WiFi router to get Internet in your smart TV. The process is similar as you connect a computer to Internet but the keyboard of your TV is the remote control, some smart TVs can work with standard wireless keyboards and mices to surf Internet as with a computer.
Nov 01, 2013 | Televison & Video
What does the H symbol on the top upper left corner of the phone screen mean? How come it keeps switching between an H and a 3G symbol?
probably the state of the internet connection H could be HSDPA and 3G obvoiusly 3G. Which phone?
Nov 25, 2010 | Cell Phones
Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Feb 26, 2009 | Belkin (F5D72304F5D7000) Router
3G Symbol
According to the manual this symbol means "HSDPA network connected"
Sep 24, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Computers & Internet Logo
102 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
