See if you can find the factory reset setting. That should restore the settings to normal. Though remotes made for other JVC devices might work some of the controls, they can cause complications.
American E-Bay does seem to be selling the original remote at the moment. It might be second hand, but at least you know it will work.
More than likely its bad capacitors on the Power supply very common problem with most models. You can get repair kits or replacement power boards from www.tvrepairworld.com
The set is in stand-by mode,this problem is due to internal power supply failure,if you are technical person check power supply voltages to find out the reason of stand-by or call some technical person to rectify the same.
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
If there was a dvd in the tray and the cable guy moved the dvd player, there's a good chance the disk might have slid off the tray and is now blocking the tray from opening. Also if the machine was moved there is a good chance the tray/laser lock might be on. It is a switch or button located on the bottom of your dvd player. Check your manual for exact placement. It is built in for shipping purposes so they don't get broken from rough handling. Hope this helped!
Ideas
1/ Turn power off for a while at powerpoint for as long as you want 5mins should be fine then turn on and try again.(which youve probably done already) as well as looking up your model number on the net to attain a info on your system.
Does the remote still work if so try to find unlock in menu/setting/functions but if it requires a digit code then youll need the manual as it could have an override built for cases such as yours.
start at jvc.com/dvd5.1 surround and find your model
good luck
