Question about Garden
Can’t remive oringinal line head to put new one on my troybilt TB 525 EC trimmer. Can’t figure a way to lock it up so I can loosen head
  • 459 Answers
U do. OT have to remove head to reload. To remove head use channel locks on the center lock y just hold the entire head from turning if urs is like my unit
Posted on Mar 03, 2019
6ya staff
SOURCE:
Joel Friedenberg
  • 1114 Answers
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Posted on Jun 21, 2009
Anonymous
  • 115 Answers
SOURCE: Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Posted on Jul 06, 2009
Anonymous
  • 163 Answers
SOURCE: I have a remington tap N go 12 weedeater. I
got to be a way to reload it
Posted on Jul 26, 2009
Anonymous
  • 61 Answers
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Posted on Apr 14, 2010
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
Highlander72
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
I want to remove the trimmer head from my Troy Bilt straight shaft trimmer model no. TB635 EC. Can you help?
Try the manual here
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/trimmers/TB635_769-10058.pdf
Oct 01, 2017 | Troy Garden
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Tb70ss fuel diagram troybilt
Hi Ernie..
I think this is what your looking for
Please rate me
Bud
Oct 31, 2012 | Troy Garden
Cant get the heas off trou-bilt weedeater on a 4 cycle # TB 525-ec
the bolt on the end has left hand threads not right hand the most bolts have
Apr 07, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Feb 25, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Troybilt 4 cycle trimmer (TB475ss) won't start. New tank, new plug, new gas??? Will occasionally start, run for about 10-15 secs, then stops. Won't restart. Help!
Take the plastic cover off that covers the muffler and cylinder head. I've had 2 cylinder heads crack. The trimmer still ran but had little to no power and would not throttle up. First head cracked at the head bolts. The second one cracked above the bolts. The side that has the carb and fuel tank is harder to see and you must remove the carb and fuel tank to check. Also I've read online that this trimmer has a problem with the fuel line cracking at the bulb and in the tank.
Sep 12, 2009 | Garden
No Spark
put the kill switch back frist using a test light you can check for spark your coil is set @00.8tm..... good luck
Aug 15, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
47 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
