Question about Haier Freezers
Haier LW110 access plus 3.9 cu.ft freezer ....fast freeze button on it works,turn fast freeze button off it stops working even with the green power light on .
    Master:
  • Haier Master
  • 745 Answers
Probably a fault in that switch
Posted on Jul 11, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Haier 5.0 cu. ft. HCM-050 not freezing
I have the same freezer and recently it quit freezing. The thermostat is my problem. I checked the power outputs to turn on the compressor and it was not there until i tapped on the thermostat. I am currently trying to find another thermostat
Posted on Oct 02, 2007
Anonymous
  • 136 Answers
SOURCE: Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Posted on Mar 13, 2008
douglas smith
  • 1462 Answers
SOURCE: Neff 3.8 cu ft freezer.
if it works on superfreeze then the stat is faulty. all that supoerfreeze does is to bypass the stat. easy job
Posted on Sep 10, 2008
Anonymous
  • 124 Answers
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Posted on Nov 21, 2008
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: How much amps, volts and
all this is on label on equipment.
Posted on Feb 28, 2011
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Feb 10, 2015 | Whirlpool 10 cu. ft. / 283 liter Chest...
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
The freezer freezes two hard , there are 2 switches on it are they both suppose to be on?? one is orange and one is white.
Well hello...on your freezer...the orange switch is for "fast freeze" and should not be on constantly...only when you want to freeze items really fast.If you have it on...turn it off.Also do you have the temp control set at maximum...If so...try to reduce the seting by one number.If not...leave it as is.Give the freezer about 24 hours to re stablize.That should do it...also...you will notice a reduction in your electric bill as the fast freeze switch causes the unit to draw a greater amount of electricity..MAKE SURE the orange switch is off...I hope this was helpful....PEACE...
Jan 05, 2012 | Haier 7.3 cu. ft. / 207 liter Chest...
My freezer comes off and on
Please set your thermostat a bit lower to prevent this problem.
Regards
Jan 08, 2011 | Haier 3.9 cu. ft. / 110 liter Chest...
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Unfortunately this sounds pretty surely like you need to get your freezer checked for leaks and re-gassed; control on refrigerants these days makes it very difficult and probably illegal to try and do this yourself, but any refrigeration repair guy should be able to do the job. slight worry is that the compressor could have seized, but this is not so often the case, sometimes a sharp whack can unjam a compressor, but get the fridge guy to look at it if he does the gas. Hope this helps :)
Mar 11, 2007 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
115 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
