I have a ZTE Z3001S model number with Android version 7.1.1. I can connect to wifi, but within 30 seconds it forgets the connection. I have to turn wifi off and the reconnect again. All other devices in home are working on same wifi connection fine. This only started happening yesterday, before that it was fine.
Chuck the ZTE phone in the bin & buy a better phone. They were distributed by Telstra Aust, but are no longer supported
SOURCE: My Iphone 3G won't connect to home wifi.
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
SOURCE: windows vista laptop failing to connect to some wifi networks including my home one.
Open Network and Sharing Center, Manage Wireless Networks, Remove your Home one. Exit Network and Sharing Center. reboot machine, Try to reconnect to your home one. If that fails, Release and renew IP : http://www.cs.cmu.edu/~help/networking/IP_renew.html
SOURCE: i could not turn on my the wifi on my chromo tablet
When you selected forget it erases the SSID and password you entered to connect initially so you will have to re- enter the info to reconnect!
