SOURCE: Paper jam error light on kodak esp 5
NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
SOURCE: Kodak ESP-3 Printer Red Flashing Light
Couple of things.
1. Look inside the printer by the print head. On one side you should see a felt pad of some sort. Make sure this has not come loose. If it has, it can block the path of the print head and will read paper jam. I have seen this mostly with the ESP 5, but I suppose the same could happen with the 3.
2. This way is kind of long but will clear a lot of problems. Open the top of the printer and remove both cartridges and the print head. Unplug the power supply and close the printer. Wait about 30 seconds. Now plug the power back in and wait until the printer stops moving inside. Open the printer and instal just the print head. Unplug and wait 30 seconds. Repeat this procedure with installing the black, then the color. Make sure you unplug for 30 seconds and wait for the internal parts to stop moving between each step. his should fix everything. It has worked for me several times. These really are a decent printer, just a little glitchy sometimes.
3. Make sure a paper has not gotten wadded up and is hidden inside to the left or right of the print head. I have seen this twice in the ESP 3.
Hope this helps.
SOURCE: i have Kodak esp 5 all in one- says I have paper
f you have tried the Kodak standard instructions for clearing the
paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
