Question about Beko Washing Machines
Have watched any of your videos stil not got a solution to my problem ,I have an beko washing machine wm84125W model ,the problem is water was not come in then I changed the valves then water starts come in but non stop keepon running water at same-time is drilling the water away ,have changed the water level valve still problem not stop and is not spinning .What should I do next?
6ya staff
SOURCE:
Anonymous
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
Anonymous
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
No_ky
  • 59 Answers
SOURCE: Avanti W789SA Water valve problem
Where do you live.I know some chenese guys who sell the spare parts.
Posted on May 07, 2009
john_cross
  • 6277 Answers
SOURCE: Hi, I have a Beko wm6123w
There is a separate motor for all of the draining parts of the cycles.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 25, 2011
Testimonial: "Thank you John...wasn't expecting anybody to come back to me or as quickly! I will try now."
john_cross
  • 6277 Answers
SOURCE: my beko washing machine has
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
John C
Posted on Jul 12, 2011
I have a beko washing machine wm84125w and the other day during The cycle there was smoke coming out from the back and smelled burning, I turned it off. The day after I turned back on and used two times...
it seems like your heating element is broken and needs replacing you will need an engineer to do this its very complicated not for the normal guy eric
Dec 27, 2017 | Beko Washing Machines
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Forty cycle takes some water in then stops
    Beko WM5100W Washing machine wash/spin problem ...
    ? 3:59
    https://www.youtube.com/watch?v=rih6H1cpu9Q
    Jun 12, 2012 - Uploaded by ilona ilona
    problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
    Washing machine stops mid cycle - White Goods Help
    www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
    Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
    My beko washing machine will not fill with water or it wont spin.
    This Beko washing machine video will help you
    We work very hard in our warehouse making free video guides for you all on cookers, ovens and washing machines Etc. Buy Paul Beer
    Nov 01, 2014 | Washing Machines
    My washing machine wont spin
    Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
    Also check all waste pipes are clear and inspect the pump I have included this video below.
    At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
    How to replace Beko Washing Machine Motor Carbon Brushes
    you might find this test video helpful but only do it if you have checked the motor
    Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
    My beko wahine machine wont drain
    Buy Paul Beer
    Feb 10, 2014 | Washing Machines
    Beko washing machine wme7247w showing E08
    Beko Washing machine? What is that a French Model? LOL
    Your water inlet valves (hot/cold) are bad and need replacing.
    If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
    Jan 19, 2014 | Beko WME7247W Washing Machine
    Water wont empty from my machine
    Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
    Nov 04, 2012 | Beko WME7247W Washing Machine
    Beko washing machine wont drain or spin water stays in drum
    the pump itself could be blocked or broken check inside pump first for any obstructions
    Jul 01, 2009 | Washing Machines
    Washing Machines Logo
    29 people viewed this question
    Top Beko Washing Machines Experts
    Eric Taylor
    Marvin
    Marvin
    Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
