Question about Sony BRAVIA Televison & Video
My sony.bravia KDL-46xbr9 is repeatedly turning on and off. Why? Is there a way to do a hard reset? Don't have original remote. Connected to xfinity for viewing tv.
    Scholar:
    New Friend:
  • Sony Expert
  • 82 Answers
Aron,
To perform a reset you will need to disconnect the TV completely from power for at least 30 seconds, if this doesn't resolve your problem then you may have hardware that has expired in your device. Without physically looking at your device I can't say with certainty what your problem is, it could be your PCB. There are video's online you can visit on how to test a PCB for faults.
If you are not comfortable troubleshooting your device I would suggest contacting a local electronic repair shop near you, however I will link you to a generic instructional video showing you how to perform basic troubleshooting of your device.
Hope this helps,
Best regards
https://www.youtube.com/watch?v=qxG3hmmvkJs Testing LCD TV Power Supply BoardsSTEP BY STEP
My sony.bravia KDL-46xbr9 is repeatedly turning on - fixya-aioep5zungdwqwtpjd23ghga-3-0_0.png
Posted on Mar 08, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
mahesh patel
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
Anonymous
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Posted on Feb 21, 2010
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
Sony bravia KDL-46XBR9 screen went white
If audio is OK, the fault is with its T'Con board. If audio too is not there, the main board is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 10, 2014 | Sony Bravia Kdl46xbr9 46 1080p Lcd Tv...
Sony Bravia KDL 32EX400 stuck on channel one
It sounds that the main system memory IC has damaged. Before make it sure, just make a hard reset to this set, and check whether it helps you. To make it a hard reset, just unplug the AC cord from AC mains wall socket, and re-plug it back after 30 minutes or so.
If this do not help you, check and replace the main system memory IC.
Aug 22, 2012 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
I have connected my DVD player to the Bravia tv. How do I get it to operate, I don't know what to do?
You need to toggle through the inputs on the television. Look at your Sony remote, to the top right of the directional keypad, is an "input" button. Turn your DVD playervon, and then press that input button until you see something on your tv screen.
Aug 13, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a 52" sony bravia MODEL# KDL-52V4100. it comes on but every 3 minutes it shuts off and restarts. have gone through all the timers and settings but still does it. i dont have the remote that came...
Try website like Remotes.com to buy an exact remote to the original remote.Tries tv unplug,replug tv an hour later,the tv will reset itself back to the factory setting,could solved ur problems.
Oct 11, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Initial setup on Bravia 26" won't come up
Try resetting the TV to the original factory settings. After resetting the TV to the original factory settings, you can get the initial setup screen to select Antenna. Make sure that the cable from the Antenna is connected to the TV.
Follow the steps given below to reset the TV to the original factory settings:
(i) Turn ON the TV.
(ii) While holding down the Up arrow button on the Remote control supplied with the TV, press the Power button on the TV set. The TV will turn itself off then back ON again.
(iii)Next, release the Up arrow.
Sep 08, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV volume goes down with out being touched
may have a sticky button or a shorted transistor switch.
Jul 01, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Dec 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
