SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
SOURCE: Can a serial number on a Gucci watch be checked for authentication?
Hello, I've just read here: http://www.ask.com/beauty-fashion/check-gucci-serial-numbers-a0287af75d5c1830#full-answer
that Gucci's Customer Service should be able to verify the serial number. The main customer service number is: 1 (877) 482-2430
SOURCE: My Gucci serial number is 10860032 is it fake or original
Bobo, contact Gucci. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gucci Official Site United Kingdom
Top 10 Tips to Identify Fake Gucci Watches
The difference between real gucci and fake gucci
