Tablets & eReaders Logo
Dana Bennett Posted on Mar 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nextbook 8.I don't have much space left.I have moved what could to the SD card but still not much space left.is there and update or upgrade for this tablet
Repairlass1989
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 208 Answers
  • Posted on May 13, 2019
Repairlass1989
Expert
Level 2:
Passionate:
Answers
208
Questions
Helped
58984
Points
280
Delete apps what u do not want
5 Related Answers
cinek79
IT aid
  • 320 Answers
  • Posted on Apr 01, 2014
SOURCE: Im using a tablet and I cant move apps and games
Hi if you want move apps to sd card go to settings, application and there press on the app which you want move. On the next screen you will see details about the app and a button move to sd card, just press it and the app gonna be moved to sd card. Bear in mind that some of the application can't be moved you will see then grey button.
electricks
ELECTRICKSUSA
  • 282 Answers
  • Posted on Apr 13, 2014
SOURCE: What happened to my apps?
You could go to settings and restore your apps. Will be back or it might be backed up with your goggle accou
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
spshort
EasyPC123
  • 36 Answers
  • Posted on Aug 13, 2014
SOURCE: how to reinstall android 4.2.2 jelly bean in nextbook 8
You could download a JB rom for your nextbook 8 and flash it using live suit or do a factory reset by turning it off then hold down the vol up button then hold the power at the same time until you get recovery appear then you can do a factory reset.
Testimonial: "I have tried the factory reset with power/volume button. First screen is NO COMMAND hit up volume did reset and same. where is reset button on back. Only have speaker holes."
shadowchb
  • 268 Answers
  • Posted on Dec 04, 2014
SOURCE: i have an irulu tablet. I inserted a 32gb sd
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
William Alequin
  • 932 Answers
  • Posted on Jan 02, 2015
SOURCE: The charger port broke off in the tablet of Nextbook 8. Is there a way to remove/fix this?
To fix you must take apart the device. I suggest that you search for "How to repair XXXXXX on Nextbook 3"
If the port is not solder, you should be able to fix it. Best of luck.
My NextBook 8 doesn't allow me to move apps to the SD card, is there a way to change that?
No there isn't away to do that. The only way to do that is to download the software from a third party website and install it on to your SD card just like you would on a normal Windows Laptop.
I have a16gig external sd card still unable to down load games says insufficant storage space
Hi, I don't understand much, can you be specific, you can try to redirect instalations from device internal memory to sd card
How do I use my SD card? My programs will not update saying there is not enough room.
If you go into where your apps and files are listed you should have a choice to be able to move them to the SD card rather than using the tablets memory.
This may be in the " Settings " area which looks like a Cog on most android apps.
2answers
How do i use the extra space and memory card on my tablet?
You need to format it as NTFS instead of FAT32. FAT32 will throw up warnings when you attempt to copy over anything over a few gigabytes. Plus, NTFS is more stable and secure. Try that first.
Is this happening when you try to copy over large files or a large number of files? I'm curious to know what the specific issue is. Could you tell me if you can copy anything over at all? Have you tried the SD card in another device?
Either way, check the formatting to make sure it's NTFS. Good luck!
1helpful
How do I download games?
You need to move app/pictures/mps or what is taking up space on the main storage to the SD-card.
I added a 16GB SD card to my tablet because it was low on space. Transferred everything to SD card that could be transferred but now updates needed for games will not download stating lack of space.
Move some of the items from internal memory to you we card. I had an issue moving an ad card from one device to another and had to reformat the ad card in the new device.
How do I move memory in my Nextbook 8se premium around to better manage it?
As far as i know this meathod usually works with apps. First you go to settings, second you go to storage, third you go to something like apps, fourth you select an app, fifth you select move to SD card or move to internal memory depending on where you have your data saved. I hope this helps anyone with this problem, im no expert but i will try my best to help
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
