SOURCE: IBM Wheelwriter 15 Series II -- the paragraph symbol appears when we type the @
change your wheel with word`s and everythin is ok,possibly mark @ is broken on typewrither wheel
SOURCE: Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
SOURCE: keyboard trouble
you need to reload that software that came with the keyboard. Uninstall the keyboard from device manager :- Control Panel>system>device manager. Then reload the software for the keyboard, which should also have the drivers. If you do not have the software, let me know the make and model of the keyboard and I will see what I can do.
Hope this helps
SOURCE: Zoom Key Does Not Work
Normal
0
Go to
Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on KEY SETTINGS.
3. Then set up the key by selecting from the drop down.
Hope that will help
some. Bud
SOURCE: HI, KEYBOARD IS NOT WORKING PROPERLY, IF I PRESS H
HI DEAR FRIEND
I know what problem having you
step1 right click to my computer
step2 click manage
step 3click device manager
step 4clic keyboard
step5 UN install the the keyboard driver
step 6install CORRECT keyboard DRIVER IN YOUR SYSTEM
OK
