SOURCE: divx greek subtitles
look in the menu and try to change the encoding, There should be 3 options, Unicode, Cyrilic & Greek. Select greek if the .sub or .srt file is in ANSI encoding, or select Unicode if the file is in UTF-8 or Unicode encoding.
To find out the encoding of an .srt file the simpliest thing to do is open them with notepad and got to "File" -> "Save as", The encoding should appear in the bottom of the dialog.
SOURCE: emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
SOURCE: Hi, how do I turn
Some DVDs can't change the Audio or Subtitles in Button of the Remote, try change in the Menu,
Try again with the Remote with another DVD Disc...
Bruno Gamba
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there. Worked for us - got the idea from another fixya post.
SOURCE: SUBTITLES WILL NOT GO OFF
Be sure to check the closed captioning of the TV as well and turn it off. This worked for me.
