Low setting on knob will not heat. Both auto dry high and timed high heat work fine.
SOURCE: Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
SOURCE: Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
SOURCE: Maytag DE 412
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
SOURCE: low heatworks, high heat does not.
it sounds like you need a set of thermo switches. one may have stopped functioning. a service tech can test them easily. should be low cost
SOURCE: Huebsch Electric Dryer won't dry
Look for a faulty high limit due to excessive lint buildup in the machine. That or either the element is bad. very simple machine to repair. Huebsh electric? Better look at old style speed queen dryers for comparison. better yet Click THIS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
