Video Cameras Logo
Posted on Jun 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon FS200 - I can't get video to play back on a TV. I connect the supplied cable to the AV OUT terminal on the camcorder and then plug in the audio and video connections on the cable to the correct color coded terminals on the TV. But when I hit the button for playback mode on the camcorder nothing happens on the TV. The video plays on the camcorder view screen (no sound), but the TV just shows whatever is on the channel to which it is tuned. What am I doing wrong?
Tony Parsons
Level 3:
  • Canon Master 6,405 Answers
  • Posted on Jun 11, 2017
Tony Parsons
Canon Master
Level 3:
Answers
6405
Questions
Helped
1651837
Points
20272
Tune the TV to the correct input for the camcorder, not another channel
Steven Brandon
Level 3:
Master:
  • Canon Master 462 Answers
  • Posted on Jun 10, 2017
Steven Brandon
Canon Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117833
Points
1705
Post picture of hookup but you may have a bad cable.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5 Related Answers
A
Anonymous
  • Posted on Dec 27, 2006
SOURCE: Jumpy Playback Through TV
but the problem sounds to be that the playback on the LCD is fine while the TV playback is problematic. I am currently having a similar problem using the three to three connection to the TV: audio is fine picture is completely distorted. I tried to adjust NTSC playback mode and changed it to NTSC and not to PAL TV, but nothing changed. Can you only use S-video lines with these cameras? sony dcr
Anonymous
  • 73 Answers
  • Posted on Aug 02, 2007
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Anonymous
  • Posted on Jul 18, 2008
SOURCE: No display on view screen but able to record and play by connecting to TV
I have the same problem: Technical Service says flexible tape between LCD and camera could be open in some lines. The solution is to change that tape.
chuckfilms
  • 19 Answers
  • Posted on Dec 30, 2008
SOURCE: no sound on playback
The S-video cable carries picture only. You need to also hook up RCA audio cables from the camcorder to the TV
Anonymous
  • Posted on Mar 29, 2009
SOURCE: Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
How do I hook up my old Panasonic Palmcorder IQ to my smart TV or my computer so I can play the tapes?
To output audio, use the stereo cable to connect the camcorder to the TV (insert terminals other than the yellow one). 3. Turn on the camcorder and the TV. On the TV, select the component terminal to which you connected the camcorder as thevideo input.22 Jul 2010
2answers
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
I want to use my canon A 720 Is camera as a webcam, please guide
Welcome to FixYa.
You can use the supplied AV cable to shoot or playback images using a TV/computer.
1. Turn off the camera and the computer/tv
2. Connect the AV cable to the camera's A/V out terminal(open the terminal cover and plug the AV cable in all the way)
3. Plug the other ends of the cable to the VIDEO IN and AUDIO IN jacks on the computer/ TV.
4. Turn on the TV/ computer and switch it to video mode
5. Turn on the camera.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
2helpful
I can't get my videos from the camcorder to the
You should have got a CD called Digital video solutions or something, on which you may find an application to upload and edit video. You should have also got a USB interface cable to connect to your PC. You connect that to the camera may select playback on you camera and you should be able to upload video. You can also download instructions from the Canon website
Need to transfer order VCR-C tapes to DVD How
You will need to borrow or buy a DVD-Recorder, either way it's best to follow the manuals instructions on how to connect your camcorder (external device) to the DVD Recorder for Recording to DVD. Most camcorders come with a set of AV (audio/video) Cables for this purpose. On your camcorder you will find a little rubber door that houses the terminals to connect your cables to. Depending on how old your camcorder is you will find a Yellow (video) and a White (audio) and on the newer ones that have stereo capabilities...you will have a Red (audio), all these connections are video and audio Out-Inputs and should be connected to the Video and Audio "In" terminals on the back of the DVD Recorder. Now make sure your battery is fully charged (It's best here to use an AC Adapter for your power supply instead of your battery, which also usually comes with your camcorder if bought new.) and that your VCR-C tape is loaded and completely re-wound. Now if you want to watch this on your TV while you are recording to DVD...you'll need another set of AV Cables that come with a new DVD-Recorder, and hook these cables on the Out-terminals on the back of the DVD- Recorder and the other end of the cables to your TV's Video/Audio-IN terminals on the back of the set. Finally...Set your camcorder switch for Playback, turn on the DVD Recorder, And turn on your TV. Now you can go ahead and record all your VCR-C tapes to DVD! Any other questions? Contact me directly at [email protected]
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Canon ZR80 no image on TV in playback
Make sure your AV cable is plugged firmly into the camera. These cables can problem your observing when they are not fully "plugged in". If that does not solve your problem, the front pcb (board underneath lens assy) may have a bad connection. I charge a flat rate of $125.00 for camcorders including parts in most cases with a 90 warranty. If the repair cannot be made for this price a free estimate will be given. Contact Frank @615-400-1440 or e-mail [email protected].
2answers
DC doesn´t has image
try a different av cable or jiggle the connectro on the dreamcast av port
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
