I was doing laundry in 90 then it just stopped and wont turn on again. I checked the cable connected to other plug same result. Drained the water that was in there. checked the lock of the machine even though it was turning on without closing the lid. I dont know what to do. Please help
SOURCE: machine won't work. kenmore 90 series
Might be a broken motor or a blown fuse. I would suggest having your machine looked at by a specialist. If it's old, you might consider replacing it.
SOURCE: Fisher & Paykel Washing Machine
Close your external inlet valve to the machine. Disconnect hose of washing machine from the valve; keep a bucket there and open the valve to see if water comes well. Next check the screens (filters) on the hose, clean well. This shd be done on both ends of the hose/s. Refit carefully. Check for leaks. If water still (don't forget to open the valve!) does not enter machine change the inlet valve of your wash machine. Can be done yourself. Rate me pl...........if helped.
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
SOURCE: My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
SOURCE: Programmes for Fagor Select FU-1047
Sadly I don't have the answer, I have the same predicament as you! I don't suppose you have had any luck finding one have you?
