SOURCE: 935 service printhead error
hello
check this link out
you will get aal the answers for all the printer issue s
http://www.all-laser.com/cgi-bin/webc.cgi/error_lex.html
let me know if you need any assistance
SOURCE: optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Hello. Unfortunately, if that's the case, there's not much you can do about it but have it serviced. Hope I can assist you more with it.
SOURCE: 935 Service Printhead Error
This means that the printhead is defective. The printhead is the actual laser scanner unit which is under the top cover. It will need to be replaced.
SOURCE: 935 Service Printhead error
Error 935
Printhead Error - Mirror motor unable to reach operation speed Check cables, look for chafing or damage to ribbon cable at sharp bends around rear cover. Replace printhead or ribbon cable.
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
