When i switch on the printer its saying this error code, Call Srvice 0150:0171913. i hope you can help me with this problem.
Thanks alot!
Your machine has a FIRMWARE problem. You must call a Copystar or Kyocera Technician to resolve .
Or just download the files from:
http://rapidshare.com/files/199500501/kyofs2000d_firm.zip.html
extract all files from the zip, keeping folder structure intact.
Place all files/folders on a fat32 formatted flash disk. plug into printer usb port, turn on. The screen on the printer should say something re firmware or something (ie different from normal boot). then, once its settled down, turn off, remove flashdisk and power on again.
Corrupt firmware will now have been replaced.
If issue recurs, do it again. (Until you get sick of doing it and just replace the printer)
If it keeps happening, suspect dry solder joint on mainboard - probably not an easy or cheap fix.
seems to be heat related.
ie, will often work until it is power cycled and then turned back on again, it fails....
hope this helps
joshAU
