Question about Air Purifiers
What does an exclamation point in a triangle mean on a Dyson hp04 air purifier
  • 125 Answers
Its dirty and needs to be cleaned
Posted on Mar 15, 2019
6ya staff
SOURCE:
co7196
Ned C Cook
  • 3433 Answers
SOURCE: The triangle with an exclamation point turned on
It indicates a passenger air bag faul. Try turning off the passenger air bag and then back on
Posted on Jul 14, 2009
David P
  • 34 Answers
SOURCE: dashboard symbol - triangle with an exclamation
Hope this helps!
Posted on Oct 30, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: what does the warning light - yellow circle
Are refer to the Brake System; in RED and YELLOW condition, continue driving cautiously:
More details about this Warning Lights you can find in the 2003 Mini Cooper - Owners Manual (page 16 and next).
I really hope helps with this (remember rated this help) Good luck.
Posted on Jan 08, 2010
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: what does the warning light of a yellow triangle
Standard Vehicle Stability Assist™ (VSA ®) with Traction Control and Brake Assist Vehicle Stability Assist (VSA) is an electronic stability control system that works in conjunction with the Pilot's drive-by-wire throttle and its 4-channel ABS systems to enhance controllability while the vehicle is accelerating, braking, cornering or when the driver makes a sudden maneuver. VSA functions by applying brake force to one or more wheels independently while also managing the throttle, ignition and fuel systems to help the vehicle maintain the driver's intended path of travel.
The VSA system constantly analyzes data from seven sensors that monitor wheel and vehicle speed, steering input, lateral G forces and yaw rate. It compares the driver's control inputs with the vehicle's actual response. Whenever the actual response falls outside of a predetermined acceptable range, VSA intervenes with a corrective action.
For instance, if VSA detects an oversteer condition, the system may apply braking force to the outside front and rear wheels to counteract the unintended yawing effect. In the event of understeer, VSA may apply braking to the inside rear wheel while reducing engine power to help return the car to its intended course. VSA also provides a limited-slip differential effect for the front wheels by applying braking force to a slipping wheel, thereby redirecting driving force to the wheel with more traction.
There is a button on the lower left part of the dashboard that says "VSA". Push it and the triangle will dissappear (this should only be turned off if you are using a spare tire that is smaller than the rest of the tires).
Good luck.
Posted on Mar 02, 2010
Poncherello
  • 312 Answers
SOURCE: the yellow triangle with an exclamation point is
The Vehicle Stability Assist system is turned off. Vehicle Stability Assist (VSA) is an electronic stability control system that works in conjunction with the Pilot's drive-by-wire throttle and its 4-channel ABS systems to enhance controllability while the vehicle is accelerating, braking, cornering or when the driver makes a sudden maneuver. VSA functions by applying brake force to one or more wheels independently while also managing the throttle, ignition and fuel systems to help the vehicle maintain the driver's intended path of travel.
You need to find the VSA button on the dash and push it, this will activat the VSA and turn off the yellow light.
Posted on Apr 05, 2010
What does E1 mean on my green air purifier
Probably ozone plate needs to be cleaned or replaced.
Jul 06, 2014 | Alpine Air XL-15 Air Purifier
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
My "prove-it" light indicator does
How long have you owned the machine? If bulb is out, (the one deep inside the machine) it means the RF ionizer or needle point ionizer isn't working. Clean both of them and you should get the bulb to come back on.
Jun 22, 2011 | Ecoquest Living Air Classic Air Purifier
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
IS THIS PURIFIER REALLY WORKING IS IT a hepa or carbon filter?
Most particles in the air are neutral in charge. Meaning they have the same amount of negatively charged electrons, and positively charged protons. A common type of air purifier uses what is called corona discharge air purifier. These type of air purifier create molecules called ions. When particles pass through these air purifiers electric current makes these particle either positively charged or negatively charged. Once these "ionized" particles from the air makes contact with objects that are opposite of thier charged, they stick to them instead of lingering in the air, or they may clump with other particle untill they are too heavy and fall to the ground. Filter types air purifier are not so good since they require periodic filter replacement. These type of air purifier are usually part of the air conditioning system. The purifier picture I see are the ones i just mentioned, and they are not filter types.
Nov 25, 2009 | Sharper Image Professional Plus Ionic...
How to clean my Lasko 42 Wind Curve Platinum?
Yep... ALL the screws in the back mus come out as well as the base. The only real problem I had was that 2 of the screws were randomly triangle drivers instead of phillips/straight combo. Ya know they do it just to tick you off...
Nov 02, 2009 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Copper contact points broken
There is a repair outfit located through the internet that seems reasonable for approaching for a more involved repair job. Contacting them may get you the parts you require.
The one I looked up had rebuilds available, so you might be able to get a replacement for a better price with your old one exchanged.
If you go this route, just do a web search for Ecoquest air purifier parts/repair
Jan 17, 2008 | Ecoquest Fresh Air Air Purifier
EcoQuest Flair Air Purifier
get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as possible..to a quarter of an inch!
Nov 14, 2007 | Ecoquest Flair Air Purifier
Ionizer
IONIZERS to not PURIFY indoor air. IONS are either NEGATIVE or POSITIVE. In this case, the NEGATIVE IONS are the 'GOOD GUYS!"
An ionizer will usually put some negative ions into the air while trapping, just like positive/negative magnets would do- SOME of your airborne live contaminates onto a metal plate inside the ionizer. When you pull out the plate with this smorgasborg of contaminates to wipe it, some of them can go airborne again, plus you have a dirty cloth ripe with contaminates on which you should then throw away. You haven't PURIFIED your air-you've just added some negative ions to your air, which will make your air feel light and lively- but still not PURIFIED.
Our SUN AIRE purifiers not only PURIFY indoor air SAFELY and EFFECTIVELY like SUNLIGHT, but one of the side-benefits is that we replenish your NEGATIVE ION balance in your air because of our SUNLIGHT process of purifying your air.
We DO NOT LIVE in our ductwork, therefore, our SUN AIRE purifiers purify your air in your living spaces FIRST and then the allotropic oxygen can be sucked through your ductwork.
POINT-OF-CONTACT is the key to our SUN AIRE purifiers effectiveness. We recommend you place your SUN AIRE purifier as FAR AWAY from your cold air return as possible because we want you to use the allotropic oxygen FIRST, before it's sucked through your ductwork.
Thanks for your question. Please let us know if we may assist you.
www.betterair.com
Oct 04, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Air Purifiers Logo
1,501 people viewed this question
Top Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
