Question about Alcatel Lands Phones
When i get within about a mile of our airport my alcatel flip time shows 3 hours earlier with tomorrows date. (21 hrs ahead} move away, normal!
    Passionate:
    Visited the website for 10 consecutive days.
  • 186 Answers
The cell tower located at or near the airport is apparently set up to provide different time & date information than is normal for the local area.
Posted on Jun 09, 2019
6ya staff
SOURCE:
Michael Grimshaw
  • 131 Answers
SOURCE: long drying time
Did you find what it was?
Posted on Mar 17, 2008
Anonymous
  • 5 Answers
SOURCE: to turn hours and minutes into decimal
Let's say that the time is in cell C3.
Now in cell D3 type =C3*24
then format cell D3 as Number.
Hope this helps.
Posted on May 20, 2008
Anonymous
SOURCE: Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Posted on Feb 03, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Posted on Sep 16, 2009
Bill Bennett
  • 184 Answers
SOURCE: Module 3070 - PAW1300 >
Hi, Obviously you need to roll the time 12 hours ahead. If the watch doesn't receive the Atomic signal properly at first, go to page three of your manual, and try doing it manually following the detailed procedures there.
If you don't have the manual, get it here:
http://world.casio.com/wat/download/en/manual/
Take the four-digit (3070) module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Posted on Sep 08, 2010
How do I change the time on Alcatel one touch FLIP PHONE
Let's try this:
Go to Settings:
  1. Scroll down to 'SYSTEM,' then tap Date & time.
  2. Select Automatic date & time.
  3. Turn Off.
  4. Clear the box next to Automatic time zone.
After that select "Set Time"
Mar 14, 2016 | Alcatel Cell Phones
How to set led watch
What make and model of watch is this?
Sep 08, 2011 | Watches
Module 3070 - PAW1300 > AM / PM problem apparently. Everything works except day and date 12 hours behind. EX: In HNL (Honolulu) on Monday morning, September 6 watch gives correct time, but shows SUN...
Sep 07, 2010 | Casio Pathfinder Watch Green PAW1300 3V
How to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Dec 30, 2009 | Invicta Watches
When I travel and change my time zone all my appts change as well in my calendar. For ex: when I travel from LA to NY and move ahead 3 hrs--all my appts move ahead 3 hrs too which makes them all ...
I think the best solution will be to switch off the Date & Time Source.
Press Menu > Options > Date/Time > Date/Time Source = BlackBerry change this to Off.
We hope this helps!
Jul 10, 2009 | RIM BlackBerry Bold Smartphone
Day and date out of sync with time
Try rotating the analogue hand 12 hours ahead of the current time
Jun 19, 2009 | Caravell Bulova Caravelle watch
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
To turn hours and minutes into decimal
Hope this helps.
Apr 24, 2008 | Excel (SS8SATAS5128400R)
Lands Phones Logo
Top Alcatel Lands Phones Experts
Ekse
Thomas Perkins
Thomas Perkins
ray gallant
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
