Washing Machines Logo
Anonymous Posted on Mar 16, 2019
My Hoover HWM -1007 W washing machine fills water then not working what is the issue?
Tom Chichester
Level 3:
Top Expert:
  • Hoover Master 62,329 Answers
  • Posted on Nov 10, 2020
Tom Chichester
Hoover Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672166
Points
975369
Defective power switch and/or cycle timer
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on May 04, 2007
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
A
Anonymous
  • Posted on Jul 16, 2007
SOURCE: WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Anonymous
  • 1673 Answers
  • Posted on Jan 18, 2008
SOURCE: hoover 500 top load washing machine - water in-flow very, very slow
Check the water valve. Most of the hoses that are hooked to the water valve have a screened filter, turn water off, unhook hoses, check to see if they need to be cleaned. Other wise the water valve is bad and will have to be replaced.
Anonymous
  • 38 Answers
  • Posted on Mar 05, 2008
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
orzechoski
  • 77 Answers
  • Posted on May 08, 2009
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Hi My Hoover dynamic next washer model no DXC A48AW3/1-80 has an issue the machine starts to fill then appears to over fill then stops and gives an error code E02, any thoughts please
Hoover suggests that the water fill valve(s) may be turned off. Error 2 means It cannot fill correctly according to their owners manual.
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
My hoover 800rl top load washing machine does not progress beyond the fill cycle. once the water has reached the set level the start/ pause light goes from solid to flashing and nothing progresses form...
Check owner's manual. The light issue should be covered. Is it possible the tub is over filled? If so the level indicator switch is not working right. I'd unplug for overnight to see if the electronics will reset. Service Technician may be needed.
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Very slow filling of cold water. Hoover 5 Kg
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
2answers
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
