Same problem please help me :(
I also have same problem....
After installing Multilanguage support for WM, music can be heared only through headset.... but some ringtones can be played throught speaker...
After that I unistalling this software the problem wasn't solved, but after hard reset it works fine...
If u can help me solve this problem...
PS: My JAMin is on Arabic language but i need Russian language support support such as screen keyboard and hand write recognition.
PS2: I don't know why but after hard reset my batery life is changed if erlier i use JAMin with full chardge for 4 days now it make nearly 2 days.
Replace the speaker. I had the same problem before replacing the speaker. This is a known problen for jamin and mostly dropping the phone causes this problem.
Jamin is not silent.
jamin can vibrate but wont ring.
music works fine only if though a headset.
calls work fine only if through a headset.
was working fine playing music and then we tried to make a call after pulling out the headset and got no audio and as it was expecting a headset it wasnt picking anything up from the mic. maybe its a mic issue? ie mic died so jamin switches to headset? just thought of that so will investigate.
Ring tones and all sounds are working anymore.
Imate Jamin is not in silent mode
Imate Jamin is still working in Vibrate mode but no ring, no tones,
no music ...
same problem
Same for me. I did a hard reset on WM5 and also upgraded to WM6, so it's not a software/firmware issue.
jamin is not silent.
was
