SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
SOURCE: windows explorer issues
uninstall PowerDesk or My PowerDesk. Some malware camouflage themselves as PDShExt.dll, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the PDShExt.dll process on your pc whether it is a pest or the real deal. If neither program list above is installed, download http://www.neuber.com/taskmanager/index.html?ref=file.net as run the program.
SOURCE: cannot access data in my buffalo ministation orange light showing
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
SOURCE: I have a buffalo ministation
It is possible to recover data after formatting. This guy does it remotely and works off of donations http://FreeDataRecovery.us
