Question about Kyocera Office Equipment & Supplies
Kyocera 3035 xerox Machines polio and legal paper setting missing, so how to recovery those options. kindly solve this problems as soon as possible.
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
Make sure your destination setting is USA
Posted on Mar 20, 2019
6ya staff
SOURCE:
john archer
  • 186 Answers
SOURCE: Won't print out legal size paper
some machines have a setting on the tray as well as in the menu. I would check both.
Posted on Jun 21, 2007
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
Anonymous
SOURCE: won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Posted on Jan 07, 2009
Anonymous
  • 318 Answers
SOURCE: Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Posted on Mar 13, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: kyocera 3035 printing all black pages
It sounds like you have a bad charge corona.
Posted on Jun 13, 2009
What of when my kyocera 3035 is showing C2500
Description
Paper feed motor problem • LOCK ALM signal remains high for 1 s, 1 s after the paper feed motor has turned on.
Causes
Poor contact in the paper feed motor connector terminals. Defective paper feed motor rotation control circuit. Defective drive transmission system.
Remedy
Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper feed motor. Check if the rollers and gears rotate smoothly. If not, grease the bushings and gears. Check for broken gears and replace if any.
Hope it solves ur problem
Jun 02, 2018 | Kyocera Office Equipment & Supplies
Legal paper jam in Ricoh 3035
You need to review the documentation staring on page 136 in the manual, there are settings that have to be changed in order for jams not to occur. Ricoh 3035 Aficio Laser General Settings Manual Changing The Paper Size...
Mar 19, 2018 | Ricoh Office Equipment & Supplies
My kyocera 3035 print out nothing but black paper. what's hapng??
nesesitas give more information, but the problem is in the main charge corona,
replaces the charging wire crown,
Feb 24, 2015 | Kyocera Km-3035 Copier, Print,scan,fax ,...
Our service representative evaluated a misprint (illegeble words, and scattered ink smudges) that developed midway through a printing of 200 sheets. As it was on only one side of the two-sided project...
I do not think any other brand of paper will solve your problem.
What I would suggest is to run 50 through the bypass unit, turn the stack over then run the second side through the bypass.
I don't think the fuser is keeping up.
Jun 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
Apr 03, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
Stapling from the print mode
Yes, look in the printer properties in control panel to set this option before you print.
Nov 19, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Open Questions:
22 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
