SOURCE: I need driver for Windows xp for Minolta Dialta Di350
click here
you can downlaod install in computer
Thanks please let me know.
SOURCE: konica minolta 1390mf driver + windows7
Konica Minolta in Japan don't know when the 1390mf driver will be available. Still waiting also
Wayne
SOURCE: i can't find drivers for
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
SOURCE: reset admin password for konica minolta dialta
The pass code for the admin mode on the di3510 should be 00000000 (8 zerros )
SOURCE: Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
