SOURCE: PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
turn off the printer it willsave the setting
SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
SOURCE: an extra cut about 1 inch after the invoice is printed
I am having a problem where the windows test page prints fine up to a point then it cuts the test page and does not finish printing to the part where it tells you this is the end of the test page. I am also using restaurant pro and was trying to fix the problem where it does not print the scanner bar at the end of the receipt. the rest prints fine all it put is the on hold and table number where the bar code should be any suggestions?
SOURCE: I have canon mf5700 says check paper size and only prints one page of several page job
Press that button "status monitor" on the left and you'll be able to cancel the current print/copy/scan
jobs. Just press that button then you can navigate with the "-" "+"
buttons from the right to select the
job you want to cancel. Then press button "ok"
After cancelling the print job, open the cover and close the cover.
the printer resets and the error message goes away.
