Menzi Dlamini Posted on Mar 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi My Samsung scx 4623f is showing the message "paper jam in tray one", and there is no paper jam according to my inspection!
Adorjani Laszlo
Level 3:
  • Samsung Master 1,316 Answers
  • Posted on Mar 31, 2019
Adorjani Laszlo
Samsung Master
Level 3:
Answers
1316
Questions
Helped
456921
Points
2563
Verify the paper tray sensor actuator,the problem is or actuator brocken or paper part jammed under sensor and blocking the actuator.
5 Related Answers
Doc_Jim
  • Posted on Feb 04, 2008
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Anonymous
  • Posted on Sep 21, 2010
SOURCE: How to reset toner ,Samsung SCX-4623F
Just buy the reset chip!
Anonymous
  • Posted on May 24, 2011
SOURCE: tools reset samsung scx 4623f
www.ambitoner.com.co
ahi te pueden ayudar con el reset definitivo de la 4623f v99!!
there they have the solution for the samsung 4623f v99!!
Anonymous
  • 1116 Answers
  • Posted on Jun 01, 2011
SOURCE: I got 02-000 error on
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Anonymous
  • Posted on Apr 20, 2012
SOURCE: HOLA ME SALE EL ERROR
HOLA ME SALE EL ERROR #02-000 EN LA SAMSUNG scx-4623f QUE PUEDO HACER
Samsung SCX 4623F " Paper Jam Inside"
If you wish to get some details; check the site linked here. Pull up older posts.
1helpful
My printer is constantly jamming papers. What maybe the cause and how can I prevent or solve this?
Its possible the paper is not good for the printer or the internals are dirty. Check your printer physically and run the cleaning option and try again.
To avoid a jam:
  1. Use only one kind of paper at a time in your input tray.
  2. Whether you have a single input tray in your printer's driver or many input trays, tell the printer what kind of paper you have in the tray: Most printer controls include a section or drop-down list where you can pick a paper by name, type, thickness, or other quality.
  3. If you aren't sure whether your printer takes a certain kind of paper, check its documentation.
  4. When you reload your input tray, pay attention to the tray's needs, such as how the paper should be loaded and whether the length or width guides need adjusting.
2answers
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
My samsung printer scx-4521f show message: paper jam 01
Dear
Paper jam 1 caused du to the photo interupture and the lever connected at SMPS. Check the lever and sensor.
Thanks.
I have a samsung SCX 4824 FN printer- message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
1helpful
2answers
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Pinter tray is showing as empty when full.
Hi
I had the same problem, what you need to do is ruffle up the paper abit dont put it in so neat , for some reason the sensors are notrecongnising the paper (dont know why) i have used the same before...
good luck
Abdullah
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
