A
Amos Oluwase Posted on Mar 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Konica Minolta bizhub has error c2558 when a new starter D116 was replaced whatis the solution to this problem?
Adorjani Laszlo
Level 3:
  • Konica Minolta Master 1,316 Answers
  • Posted on Mar 31, 2019
Adorjani Laszlo
Level 3:
Answers
1316
Questions
Helped
457295
Points
2563
The 2558 error code refer the abnormally high toner density detected black tcr sensor.If you replaced the developer must necesary replaced the imaging unit chip,because the new developer detected the old parameters.
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Anonymous
  • 51 Answers
  • Posted on Aug 30, 2009
SOURCE: konica minolta bizhub
whot is the error code and whot model of bizhub u have???
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
jeevansingh7
jeevansingh7
  • Posted on Dec 11, 2012
SOURCE: konica minolta bizhub 164 have a service code c2558
sir machen coodc2558
rajibdip6
Rajib Barman Varma
  • 23 Answers
  • Posted on Dec 15, 2016
SOURCE: Konica minolta bizhub 215 giving error c2558
CHANGE YOUR DRUM UNIT OR DEVELOPER
What is a service code c2558 mean on my copier? konica minolta bizhub 206
Its a black unit error code
It means the black toner is not supplying to d developer you can reset error code by logging in d service mode
Bizhub 185 c2558 Error how to clean - bizhub Konica Minolta Office Equipment & Supplies
Do not know which application to download on the topic reverse phone lookup? Come here, here you will find all the information. https://besttrackingapps.com/mobile-phone-lookup
C220 gives error c2558
Did you replace the developer or did you replace the developer unit and developer????? Of course you replaced the entire unit right????? Because if you attempted to dump the old developer and add new Its not going to work.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12helpful
Error code c2558 in konica Minolta bizhub 164
help me my konico minolta bizhub 184/164 error (C2558) my mail id [email protected]
6helpful
Konical minolta bizhub 164 mahine service call c2558
machine trouble sevice call [c2558] wat a problam in konica minolta bizhub 164 printer
5helpful
3answers
56helpful
5answers
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
