Chucks ARE meant to stay tight.
You also use drill to UNSCREW THINGS.
Dc925 new style chuck parts # 33007575.of it is under go to the nearest service centre for a warranty if you have the receipt
the Chucks not really meant to stay Tight In reverse.
The Idea of the reverse, is to reverse the drill bit, after hole as been Drilled.
Or To Aid in Drill-Bit removal.
Mike @ Compurepair.
SOURCE: The chuck on my Dewalt 18v hammer drill will not
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
SOURCE: when in reverse chuck will
I would start out blowing out the chuck with high pressure air because you might have some saw dust or other item causing friction that is allowing the chuck to move. Then I would spray a lot of WD-40 down the chuck to float any contaiminents up.
I have the same problem 2 drills in the past year
I have same problem.
