Question about Simpson Washing Machines
How do i fix error E17 on a simpson ezset 7.5 top loader
  • 1,360 Answers
E17 means the machine has gone out balance. Normally, if you untangle the clothes and shut the lid, it will start again. If it doesn't, it may have damaged the out of balance lever under the top of the cabinet. It may also mean that the clutch has failed and the machine is only washing in 1 direction. This will tangle the clothes and cause it to go out of balance every load. Have a look under the machine, if there is black / brown oily stains all over the bottom of the cabinet, it is almost certain the clutch has failed. In most cases, its cheaper to buy a new machine.
Posted on Mar 22, 2019
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 75 Answers
SOURCE: My simpson top loader will not complete cycle.
More likely than not it is your control regulator gone out. This is where your rotary knob is.
Posted on Dec 07, 2009
luisa_sgro
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
AndrexT
Andrew Taylor
  • 30365 Answers
SOURCE: Please can someone help my top loader simpson 5.5kg is showing a e13 error please
E13 is 'taking too long to pump out'. You need to check the filter.
http://www.instructables.com/id/Fix-error-code-E17-E13-Bosch-Vision-500-with-Aquas/
Fix error code E17 E13 Bosch Vision 500 with Aquashield
Posted on Apr 09, 2016
emissionwiz
Marvin
  • 85222 Answers
SOURCE: Hi we have a Bosch Exxcel 7 with E17 error code. We've checked filter and pressure. Any ideas??
E17 indicates that water is leaking and getting into the bottom of your machine
Posted on Feb 23, 2017
Simpson 9.5 top loader has code Co but cannot find it in the book.
That code in some brands means a communication error between Main board and display.
Oct 02, 2018 | Simpson Washing Machines
I have a Simpson ezi Top Loader 8 Kg what does a E20 error code mean
Lift the top by unscrewing the screws in the back or remove the back panel and there you will find a code and test sheet. Very easy to follow if you follow it to a T.
Jan 20, 2016 | Simpson Washing Machines
My Simpson (SWT954) top loader washing machine wont empty, it beeps/E20. I've checked the drainage hoses (in/out of the pump)- no blockage. Can anyone tell what to check next, and where is the filter?
don't know much about them. However you can go to you tube, thuis is the link "https://www.youtube.com/watch?v=8n8lxcUf484" and you will see this Phone number 1300 000 500 for 24/7 customer support. Good luck
Jun 21, 2015 | Simpson Washing Machines
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
Simpson error code 5p
I have a error code Ld come up on my Simpson eziset 5.5 kg top loader washing machine what does that mean ? Also is it possible to replace a sensor battery for that. Model and what size battery replacement do I need to ask for
Feb 23, 2011 | Electrolux Washing Machines
Washing Machines Logo
806 people viewed this question
Top Simpson Washing Machines Experts
STEVE
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
