Question about Mackie Music
Mackie mk2 CFX16 MIXER is working on going stage show. More than two hours of working the mixer dropping main out one side. Later some time that side come back again and later drop the main out same line. I changed the input line to other near next line socket that repeated same main line one side drop. Line fader set below 0db and main mix fader set 0db position. Line in connection from laptop audio headphone out.please give me a reply to solve the problem.
    New Friend:
  • 28 Answers
Bypass the Effects by jumpering the EFX loop send/return jacks. Mine had a bad effects processor converter chip, that was random and lost main bus signal intermittently.
arlingtonguitarshop-dot:com
Posted on May 02, 2019
3 Suggested Answers
ABRsvcs
  • 4234 Answers
SOURCE: No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Posted on Feb 12, 2009
Fred Yearian
  • 5603 Answers
SOURCE: I have purchased a peavey
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Posted on Jun 28, 2011
Fred Yearian
  • 5603 Answers
SOURCE: dropped mixer about 400 mm from speaker to
Open unit. 1. Look for cables knocked off. 2. Using bright light look for circuit board cracks and broken solder. 3. Look for broken pots, especially the main slider. All of these problems are repairable by competent electronics tech.
Posted on Jul 20, 2011
Just bought the mixer and when i hook up the mixer to the amp the amp showing it clipping and no sound to the main speakers
If you are getting signal from you mixer at leaves tha are clipping your amp, then the mixer is working and at least the front end of your amp is working to register the clipping. In that case, your problem is-
1. The amp outputs are blown, check by hooking up to a different amp.
2, The speaker wires are connected incorrectly.
3. The speakers are not working. Try a different set.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
I have a Mackie 406m powered mixer. I was in a club with less than adequate power. My mixer got very hot and started smelling. Now when I turn it on, over 6 months later, it still smells and it has a loud...
More in likely a voltage drop in the club, and the mixers power transformer was fighting for power, so it's brunt or burning up, also there are capacitors that filter the AC transformer hum, they Probably need to be replaced, this can be fixed tho, parts and labor might not be cheap...
Mar 05, 2015 | Mackie Music
Mackie mixer will not work with windows 8
well depending upon the mixer and windows version you may have issues. Windows 8 is a 64bit platform, your mixer may only have 32bit drivers (x86). Try visiting the mackie forum for your mixer.
Feb 17, 2014 | Mackie Onyx 1640i Mixer
How can i get more volume on my onstage monitors thru my mackie 2404 vlz3 mixer or what is the proper way to connect the monitors
Without more information of your speakers and amps we can't really help you. The Mackie board puts out line-level signals and that should drive any connected amp or powered speaker to the full capability. Make sure you are using BALANCED interconnect lines either XLR or TRS cables. Use of TS unbalanced cables costs you 6 DB and also noise pickup. Make sure ALL your gear, amps, speakers etc are powered from a SINGLE receptacle or power conditioning module. Normally you will use the AUX outputs of the mixer by way of TRS cables or balanced lines in a snake to power amplifiers onstage which then connect to the stage monitors. If you have powered monitors the returns of the aux to the stage go to the powered monitors. A heavy duty extension cord brings power back from thee stage power to the mixer.
Sep 06, 2011 | Mackie 2404-VLZ3 Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I Have mackei fx 8 i use to connect 2 main via the main baleced outputs. i am planning buy a stage monitor bou not sure how make a connection for monitor
Buy a powered stage monitor and gonnect to the MON jack. You will select the channels to go to the monitor with the AUX knobs and the overall level with the MON slider.
Use BALANCED lines to the powered monitor... This is a TRS plug at the mixer end for sure...
REMEMBER to power ALL interconnected equipment from the same receptaacle or source, even if it means running an extension from where your speakers are plugged in to the mixer !!! The ground bounce between power receptacles within a building can destroy your equipment's sensitive input circuits.
Dec 18, 2010 | Mackie ProFX8 / SRM450 V2 PA Package
I have a mackie cfx 12 mk11 mixer and have a faulty mains out channel(xlr & jack) right mains out is ok, has this mixer got micro electronics and can this problem be repaired by any technician
Yes, there are chips in the unit and any COMPETENT tech should be able to repair.
Since both the XLR and the jack are bad, this implies something more.
USUALLY Mackie drives the XLR and the unbalanced jack seperately so the problem would be what drives the unbalanced jack.
CHECK if you have output at the UTILITY left output jack. If you do, the driver chip for the left output main is the problem.
If you don't, the problem may back up farther into the EQ.
A LOT of troubleshooting can be done on these by using the block diagram in your manual showing signal paths.
Jan 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Left side out
Test if the headphone jack also has same problem.
There are so many possibilities as to be mind boggling... HOWEVER the mixer has a lot of external connections that you can test certain things are working externally.
Download or look at your user manual that shows the signal flow map... if has a bunch of lines, triangles, and squiggly things that shows how signals go through the unit and from that one can do tests to isolate the problem.
You would need to tell us if you are using the XLR or the TRS as the outputs from the mains for example.
Jan 10, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie D8B Mixer freezes
Don't know your setup but have you checked out any possible Hum loops? Have you updated any firmware updates? Is your mains input clean (no spikes or very short drop outs of voltage)? Are you near any possible RFI, e.g. Taxi's or CBr's? The list goes on so check out the Mackie forum on the web for more. Good Luck...
Regards,
Frank.
Apr 07, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
91 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
