Bob Spencer Posted on Mar 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the sony cdp-cx200 play mp3 cd's - Sony Audio Players & Recorders
Franco Dosil
Level 3:
Top Expert:
  • Sony Master 10,542 Answers
  • Posted on Apr 30, 2019
Franco Dosil
Sony Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377272
Points
178965
Hello Bob, your Sony CDP-CX200 player, is not ready to play MP3 CDs, your Sony was introduced in 1996, by that time, the MP3 was not popularized
I sent you the link to download the user manual
Greeting Franco Dosil
Hola Bob, tu reproductor Sony CDP-CX200, no esta preparado para reproducir CD MP3, tu Sony fue presentado en 1996, para ese momento, no estaba popularizado el MP3
Te envio el link para que descargues el manual de usuario
Saludo Franco Dosil
https://data2.manualslib.com/pdf3/62/6106/610565-sony/cdpcx200.pdf?8a10123bbe195521db2a8e9083587693&take=binary
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Apr 08, 2008
SOURCE: Sony CDP-XA30ES CD Player
Try opening up the top and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, look at the back side of the optics and there should be a marking like KSS-xxx. This is the generic part designation. Any electronics supplier that supports Sony should have these.
Dan
Anonymous
  • 68 Answers
  • Posted on Jan 02, 2009
SOURCE: Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
petraman7
Scott Frye
  • 1175 Answers
  • Posted on Feb 09, 2009
SOURCE: Sony CDP-710 belt wanted
www.studiosoundelectronics.com
Please rate my help . Thanks
Anonymous
  • 35 Answers
  • Posted on Mar 02, 2009
SOURCE: sony cdp-c545 won't open
Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
Once you have the discs out, put in only one disc and see if the unit plays. If you get a disc error, you probably need to clean the lens on the laser. Open the unit, use a cotton swab that has been pre-wetted with glass cleaner to wipe the lens on the laser. Do this gently, don't press down hard on the lens. Use the other end of the swab to dry the lens. Try loading a disc with the top cover off and see if it spins. If it doesn't spin, try turning it by hand. If you can't turn it by hand, the gears have gotten out of alignment.
In this case, use your screwdriver again, noting which way the gear on the bottom of the unit spins when the drawer is going into the unit. Then turn the gear until it "pops" past one or two teeth, and then you should see the laser assembly rise up and meet the clamp assembly on the top of the tray. These are the most common problems with the 5 disc players that Sony made. Many times I could fix them in 30 seconds or less using this procedure.
Anonymous
  • Posted on Mar 07, 2009
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Will Sony cdp-cx200 play mp3 cd's
Hello Bob, no, your Sony CDP-CX200 is not ready to play MP3 CD
The MP3 began to be used in 1995 and your Sony
CDP-CX200 is development of the year 1996, they had not yet incorporated the MP3 format
I enclose the user manual where it describes the CD formats that it reproduces
Greetings Franco Dosil
Hola Bob, no, tu Sony CDP-CX200 no esta preparado para reproducir CD MP3
El MP3 comenzo a utilzarse el a?o 1995 y tu Sony
CDP-CX200 es desarrollo del a?o 1996, todavia no habian incorporado el formato MP3
Te adjunto el manual de usuario donde describe los formatos de CD que reproduce
Saludos Franco Dosil
https://www.manualslib.com/manual/610565/Sony-Cdp-Cx200.html
Sony CDP -CX200 Arm comes forward to pick up cd but goes back empty. It will not load the disc to play.
Is the second part of the arm clamping the cd? If not then the arm is probably broken and needs to be replaced.
5helpful
I need a manual for this model
You may download a copy of the manual here.
Can't erase songs. Followed the directions and still not working.
Sony cdp cx200 sounds like a PLAYER. It won't erase anything. Is the model something else?
1helpful
My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
2helpful
2answers
Do you know if the Sony CDP-C215 can play MP3 format?
No ... This is a 1st generation multi-disk player and, although it's a great, reliable, unit, it does not recognize MP3 or WMA files. You can play BURNed (automatically copied as CDI files) or RIPped copies (converted to WAV files only). The files are much larger ... but more detailed and accurate than compressed formats.
Regards.
Sony CDP-CE235 CD Player
My guess is yes. The easiest way to find out, is to take a burnt CD, and stick it in there. If it doesn't come up reading error, or doesn't remain silent, then it plays them. Let me know what happens.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
