Question about Yamaha Music
Please tell us how to solve this error of assertion failed at Yamaha psr1100 . we tried those trick of holding the right white key and switch on but it can't work . thank you
Yamaha psr4000 no sound when i play keys
To start with try a master reset, whilst the instrument is off press and hold the top (highest) sounding key whilst turning on.
When the screen displays Yamaha release the top key.
If this doesn't solve the issue then it could be a number of things as the keyboard does a self check on startup and will hang if a fault is found. Check each rubber switch is not stuck down or even missing this can cause this issue. Please report back either way.
Dan
Becketts Music Ltd
May 18, 2017 | Yamaha Music
Yamaha psr-e333. Can switch on but cannot play even the grandpiano func. Its just "yamaha" written on the display..
Dan
Becketts Music Ltd
Apr 28, 2017 | Yamaha Music
My Yamaha Clavinova accompaniment will change by itself. Is this a power issue? It was recently moved from my house to a church.
When you say changes by itself - please describe.
Try a factory reset : Hold down highest white key whilst turning on.
If this doesn't solve the issue please report more details.
Apr 07, 2017 | Yamaha Music
I have a yamaha psr 1100 show on display assertion failed
this is one of the most disturbing errors, the only easiest option is to replace the main motherboard, if you have a technician, check dry joints on the big ICs.
Jan 02, 2017 | Yamaha Music
Yamah psr1100 assertion failed
check the main board.. easiest way is to replace
Nov 23, 2016 | Yamaha Portable Keyboard
I am using psr 1100.from last week its not workina.maasege showing assertion failed.pls give a solution
Normally this indicates a problem on the main motherboard.
Always the first thing is a factory reset.
While turning on the keyboard, hold down the right most white key on the keyboard and continue holding it down until the keyboard has finished the start up.
Or
Jul 12, 2014 | Music
Internal error
Hi, Does the error actual say anything?
Have you tried a factory reset ? Hold down top white key while turning on.
Dec 08, 2013 | Yamaha PSR-S750 61 Key Portable Keyboard -
How do I reset factory settings on Yamaha p155
Turn off P155
hold top C key down (furthest white key on your right)
while holding this key down, turn on power,
keep holding key down for 3 seconds, then let go.
should default to grand piano 1 setting
Nov 14, 2012 | Yamaha P-155 Electronic Piano
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
Music Logo
69 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
