Dryers Logo
Michael Dick Posted on Mar 24, 2019
Use to take apart my Lasko hvb fan to clean. Can’t figure out how to get my new 4924 model apart
4 Related Answers
Anonymous
  • 58 Answers
  • Posted on Aug 06, 2009
SOURCE: are parts availiable for the model 4924 hvb
You may find what you need here...
https://store.laskoproducts.com/ReplPartsStorefront/Web/default.aspx
Josh Peck
  • 91 Answers
  • Posted on Aug 26, 2009
SOURCE: I have a Model #3510 Lasko Cyclone Fan and the blades are dirty
Steam works great, otherwise you can use a degreaser and hose it off. Make sure you let it dry completey and then some before plugging back in.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
SeanAA
  • Posted on Sep 03, 2010
SOURCE: Cleaning
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
chris54143
  • 4 Answers
  • Posted on Aug 09, 2011
SOURCE: Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
How to remove lent and dust from the sides. What type of tool is needed to remove the two sides for cleaning.
ther are cleaning brushes out there. look like a stick with a brush head on it. they have them in hair cutting equipment.
My hvb blower fan will not turn on. is there a fuse that i can replace?
I have the same problem after an electrical storm. Did you ever find the problem?
The fan is plugged into the electrical outlet but it won't come on.
Please check your power cable for loose connection. Check also the fuse on your fan if so equipped.
How do I fix my fan from shaking so badly?
Did you just clean the fan? If while cleaning, you bent a fan blade, even a hair it will shake. Blades are perfectly balanced. Moving one just a hair, will cause the fan to shake. Trying to re=balance the blade(s) is futile, you can get it close, but it will take somr patience. If the fan has built up dust on the blade(s) will begin to shake if some blew off unevenly
5helpful
Lasko 4920 won't oscillate...
Buy a new fan or do without the oscillation untIl it breaks worse, thenndiscard or pay a lot to have a new part made. Lasko will nOt and doesn't stock the replacement Teflon partial gear that wears out. Planned obsolescence!!! Buy a Honeywell or more reputable fan with a better warranty Hint: they don't exist anymore!! Caveat Emptor!!!!! THERE ARE NO MORE BUSINESS ETHICS IN AMERICA!!!!!!
1helpful
My fan only works on the high setting. how do i
The control panel contactors have more than likely burnt
4helpful
Lasko fan will not ocillate
check the oscillating gears usually made of plastic
2answers
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
2helpful
Not blowing enough air
the back top of the fan pry open.
Top Lasko Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
