SOURCE: Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
SOURCE: Problem after replacing convergence board
Yes, you do need to set up the convergence in order to get the picture geometry correct. the antenna and maybe some other settings will need to be restored through the appropriate user interface screens. You will need your owners manual for a guide.
SOURCE: the screen on my dell inspiron nootbook started
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
SOURCE: Samsung HLP5063W no video only sound/replaced lamp 2 weeks ago
the digital board is famous for failure in that model. You can get replacement digital boards for that model at www.tvrepairworld.com if its not listed leave them a email as they only list a few of the boards which are available.
SOURCE: Samsung LE40B550 - No Picture
I had exactly the same problem with my LE40B550 which I bought in July. I phoned the place I bought it online (eBuyer) and they put me in contact with a Samsung repair centre who fixed it under warranty. It took them 2½ weeks to fix it and get it back to me. The note that came back with the TV said they had replaced the IP board. I think the part number was H40F1 9HS.
The repair centre paid less than £50 for the board (it shows on the returns paperwork).
If you only bought yours in August, and haven't had it fixed yet, I suggest you just get in contact with whoever you bought it from and get it done under warranty.
