SOURCE: camtasia video capture = black screen,
I will not be back to your service. Your 'smilemaker' expert was rude, succinct, had no idea how to solve the problem and gave me a bad taste in my mouth. I have since identified the problem to be one of Direct X variety which is not working correctly in the register.
SOURCE: I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
SOURCE: VCR recording in black and white
The recording head, which is to the right of the reading wheel needs cleaning. it's pointless doing it your self you may destroy your machine, pay a proffesional a couple off dollars to remove the 4 screws and clean the head properly.
