Question about Bosch Washing Machines
I have a Bosch Maxx6 WAE28140. Had electrical shedding and now all the lights in the middle line are flashing. Machine does not want to do anything. Is there a way to reset?
Anonymous
SOURCE:
Anonymous
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
Posted on Jan 24, 2009
Anonymous
  • 51 Answers
SOURCE: Bosch washing machine dsplaying a key symbol and 0 - won't start
the key symbol is a child lock , look in your manual to see how to turn off this feature
Posted on Jun 12, 2009
bryan farmer
  • 112 Answers
SOURCE: hi there how do i reset my bosch classic washing
try unplugging washer for 5 mins then plug back up should reset!
Posted on Jun 12, 2011
john_cross
  • 6277 Answers
SOURCE: Bosch maxx6 service manual. Cannot find one to
I'm so sorry but this forum is not able, nor in a position, to supply any type of service manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Have you tried the manufacturer's web site direct? Unfortunately many will supply only to registered agents/engineers for obvious reasons;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 30, 2011
Roni Davey
  • 414 Answers
SOURCE: My Bosch maxx6 takes very long on wash cycle
Possibly heater fault....if you set unit to, for example, a 40 degree wash, the machine will just keep washing unit it reaches selected temp, then drain and do the rinses. If the heater is open circuit then it will wash and wash and wash until the module times out because it is not getting there and continue to rinses, making the programs excessively long. (You may also find, if it has a display that it sit at 0.01 for a long time at the end of the cycle. Not sure of your model as you have not posted it, but if you go through the test below you can test the heater.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 90 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
The tub will fill a little and if the heater is ok, after a few minutes you will hear it 'kettling', the drum does not turn during this test.
If you have a meter that checks amp draw, if the heater is ok it should read around 9 amps.
Hope this helps
Posted on Mar 24, 2013
Where is the water level sensor in bosch Maxx6?
The water level sensor is usually a pressure switch which is located into the appliance. You should remove the upper cover first and you will find it at the left or right of the drum.
More of the times, it is a round part with a connector of cables and a small thin tube goes out of it.
Please pay attention, pull the cord out from power before any service!
Feb 27, 2017 | Bosch Washing Machines
How to register my new Bosh washer
You can do so online here: http://www.bosch-home.com/us/support/product-registration.html
Dec 28, 2016 | Bosch Washing Machines
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
Mar 04, 2015 | Bosch Washing Machines
My Bosch Maxx6 Sensitive dryer starts and works for 4or5minutes than stops beeping,the light flashes and it shows F09 on her little screen.Than it doesn't work anymore in every program I can put it.What...
F09 means there is an issue with the thermostat and could be that the thermostat needs resetting. Isolate the machine from the power source before you attempt any repair on the machine.
You will have to gain access to the heater by removing the rear cover to reset the thermostat. The thermostat has a reset button which should be pressed and you should hear a click when it resets. Check that all filters are clear of any debris prior to refitting the rear panel, reconnect the power source and try the machine again.
Do not attempt any repair if you do not feel confident to do so. Call a service engineer
Sep 27, 2014 | Dryers
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
My bosh maxx6 washing machine
hiya
you will need to phone bosch and get an engineer out as the machine will be under warranty for another 3 months.
if you call anyone else out or even try to fix it yourself you will void the warranty.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 06, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
