Computers & Internet Logo
A
Ali Reza All Posted on Mar 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know how to setup the VPN on the D-Link 2750U modem
Andrew Armstrong
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 25, 2019
Andrew Armstrong
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
8449
Points
36
Https://www.youtube.com/watch?v=zKeXtyUMKjA Check out this video it might help you with your issue.
  • Anonymous Dec 22, 2021
    D-Link 2750U
    RTM READ THE MANUAL YET.
    AT THEIR WEB SIT THAT IS FIRST
    NO 2 ROUTER SETUP THE SAME, THUS THE MANUAL;
    OR ASK THEM DIRECTLY
Rick Rock
Level 2:
Sergeant:
  • Expert 258 Answers
  • Posted on Dec 22, 2021
Rick Rock
Expert
Level 2:
Sergeant:
Answers
258
Questions
0
Helped
58782
Points
780
Wow, I didn't even know that you can configure VPN on the router. I usually just use some VPN service, which I turn on before I start surfing the Internet. By the way, there are a lot of good options on EN.VPNwelt. Thanks to the reviews, it is easy to choose the best service, or try many different ones and again choose something most convenient.
4 Related Answers
Anonymous
  • 481 Answers
  • Posted on Nov 01, 2010
SOURCE: Purchased a new D-link router, Cannot open my VPN
Not all routers will pass all types of VPN successfully. My last D-Link router would pass a PPTP VPN with no problem, but completely choked on any attempt to pass an IPSEC VPN.
Since you never specified what model router you have, it's difficult to diagnose your problem beyond that observation.
Try a different brand or model of router and see if you get better results. Sad to say, I have found that the low-end routers work fine with completely vanilla networks, but they are very prone to annoying surprises like this when you try anything beyond what the average home user would try.
Anonymous
  • 167 Answers
  • Posted on Mar 08, 2009
SOURCE: VPN drops when using a D-Link Dir655 router
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Anonymous
  • Posted on Nov 25, 2009
SOURCE: Is there a way to setup a VPN with Siemens modem
NO THERE IS NOT NO!
NewScrnName
  • 37 Answers
  • Posted on Mar 05, 2011
SOURCE: I have a D-Link DVG-G1402S
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Testimonial: "it is a good solution, However even I tried put DMZ to the VPN box, it still doesn't work. I'm wondering if DVG-G1402S supporting GRE protocal at all."
What is the best modem to connect to the internet via VPN?
This is a known issue with that modem and Comcast wont support VPN from residential installations. If you want to change modems that don't have this issue, get a Motorola surfboard. If you want to change settings on the one that you have because of the protocols for assignment of addresses let me know
I have D-link 2750U (modem *** router). I am switching from BSNL to Hathway (ISP). Hathway does not supports ADSL. Suggest a work around!
ADSL modem/routers can only route from adsl line, no way you can use it as normal router, maybe ISP can provide you with its own modem router...
I have Dlink 2750u modem *** router. I am switching on Hathway ISP. They give DSL connection modem. How to use Dlink 2750?
Use an Ethernet cable to connect from the port on the DSL modem to the WAN/Internet port on the D-Link modem.
DSL-2750U Pin code
DSL-modems do not use PIN codes for WPS access,
unless there is a PIN printed on the bottom of the device.
Unable to access settings of d-link modem dsl-2750u
Your Connectivity may be on Wifi or Lan, ping the gateway and verify gateway IP is up and running if not then try to manually assign the IP to the system and try ping and if there is any proxy Please also remove the proxy from the internet settting and if still problem.Then reset the modem and then also set the IP of your system 192.168.1.2 and access the by default IP 192.168.1.1 and configure the acces point
A friend of mine has this D-Link DSL-2750U router & is trying to connect his cable internet to the router but failing to do so. We suspect it is a purely ADSL router & does not support ethernet connection...
You need a router which connects to ethernet..ADSL is connected by RJ45(Telephone connection) ... Many cable companies include a router in the Modem (Verizon) others need a router to do wireless which gets connected between the PC and the Modem . the DSL-2750U is well over $2000.00.. a normal wireless router is $50-$100... a regular router gets connected by ethernet to Modem and router ,, then has 4 other connectors .. ehternet to PC.. Also requires power supply. .. wireless has to be setup for the software.
1helpful
D-Link DSL-2750U N300 ADSL Modem Wireless Router configuration with Hathway
YES THATS TRUE. TO CONFIGURE THE ROUTER. NEED THE PPPOE USERNAME AND PASSWORD FROM THE INTERNET SERVICE PROVIDER. VPI AND VCI SETTINGS.
..THEN ACCESS THE ROUTER PAGE
..GO TO ADVANCE SETUP PAGE.
..THEN LAYER2 INTERFACE
..CLICK ADD
..CONFIGURE THE SETTINGS.
..POWER CYCLE THE NETWORK.
2answers
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
2helpful
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
D-Link Vpn Router model DI-804HV
Can you tell me the setup with your router? It should be Internet->Modem->Router->Computer If that's setup properly (the wires in the right spots) then go to the gateway IP of the router...it might be something like "192.168.0.100 "so you put that in your internet browser. The default user is "admin" with no password. Make sure to run the "Wizard" while on that page and after that go to the "Status" page and check to see if the WAN connection is connected properly.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
