Code L-4
Drum unit rotation time excess warning
- PC drum rotation time count value used for the life judgment of drum unit (the value for PC drum rotation distance calculated into the rotation time) is above the threshold value for the excess warning.
- Printing with this warning being displayed is not included in the
image warranty.
Testimonial: "Thanks!"
This means that one of your drums has exceeded its life cycle (carries toner from the cartridge) and generally run around $100 +/- to replace.
SOURCE: Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
SOURCE: sharp photocopier with error code L4-01
Hello sir L4-001 that's driving problem, check the main motor ,gears belts.
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
SOURCE: Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
