If it's an air conditioner it could mean changing or cleaning of your filter screen. On an AC unit you can have one of four typical lights..
1.. No light-no issues because it's off.
2-4 lights depends on if one solid or blinking light (either red or green) or in other senereo two staying on our simultaneously blinking. Can also alternate blinks. These are codes for HVAC technician. Sometimes if there was a surge in power you can trouble shoot only one situation-try unplugging the unit and plugging it in upside down if possible (some models allow for it) if not... Leave it unplugged for a good 5 minutes and replug it in and see if you get the lights. If not it should be good. If you do, it's time to call a technician. Hope your issue gets fixed. Be blessed...
SOURCE: Air condition not cooling. Indicator light flashes.
Check the refrigerant charge of your system. If there's no pressure in the lines, the whole A/C system will shut-off. Check for leaks in the tubes, hoses, filter dryer, pressure switches, and compressor fittings. If the system has no charge and there's no visible leak from the items mentioned, the leak could be in the evaporator coil or condensing coil.
SOURCE: 2001 eclipse air conditioning indicator light starts to flash
Need to have it service, low on freon, and have it check for a freon leak.
SOURCE: flashing green light persist even
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
