SOURCE: thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
SOURCE: Hunter 44155C Thermostat
Try calling hunter directly at 1-888-830-1326 to speak with a live support representative. If you are still having problems.
SOURCE: hunter thermostat need manual
Hi
u can fine your manual here...
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Gary
SOURCE: hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
SOURCE: Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
