Refrigerators Logo
Thulani mchunu Posted on Mar 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a LG fridge LX72LBEG. 1PH-220-240v PUJC 2520050040575. Fridge &freezer combo does not cool on both sides.checked the fan is working, compressor (R134a) just gets hot
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
  • Posted on Mar 28, 2019
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270221
Points
3723
Could be ice buildup in the cooling vents. Try defrosting for a few hours by turning off and leaving doors open (you will need to put food/perishables etc. elsewhere).
marcelakis
Level 2:
New Friend:
  • Expert 35 Answers
marcelakis
Expert
Level 2:
New Friend:
Answers
35
Questions
0
Helped
22122
Points
113
Hello
Since you did not make a complete thaw in the freezer?
Do this and then cleanly, let it dry inside, then turn it on, cause it can be an ice plug in the freezer coils
5 Related Answers
Anonymous
  • 725 Answers
  • Posted on Aug 18, 2007
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Anonymous
  • 709 Answers
  • Posted on Sep 25, 2007
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Anonymous
  • 1122 Answers
  • Posted on Nov 04, 2008
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jun 20, 2009
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Anonymous
  • Posted on Mar 21, 2010
SOURCE: whirlpool gold GD25DF FRIDGE NOT COOLING FREEZER WORKING FINE
Clean out the coils at the very bottom of the refrigerator from all of that lint/dust buildup it makes your system inefficient
Hi there.I have an Amana Side by Side Refridgerator.We are having a problem with the fridge side not cooling enough.The Freezer side is working well.Have you any tips on how to fix it myself ?Cheers.
Check fan which blows cool to fridge compartment is working. Check fridge is defrosted automatically. If not do it manually and check, there will be cooling in fridge compartment. Over frosting will cover up the fan throw behind the freezer. If not auto defrost works, switch off and restart after 5 minutes. Still auto defrost problem, do it manually or replace board.
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
1helpful
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
26helpful
4answers
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
2answers
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
