Clean your condenser coil
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
SOURCE: Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
SOURCE: GE PCG23NHMF side by side fridge freezer - stopped cooling
Although this machine is supposed to be frost-free (i.e. automatic defrost), there was a build up of frost. We manually defrosted the machine, then restarted it - the noise has stopped and the freezer and fridge are now working. However, this may be a temporary solution.
Let freezer get down in temp and fridge should start chillg.Good luck
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
wrong.
If
tips.
Check
you...
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator
Compressor
Refrigerator
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Thanks Marvin but that difficult. Too remote and owner is not there all the time. Possible to follow up on cause of issue. Possible scenarios with solutions? Please help.
Sorry about that
