Humidifiers Logo
A
Ann Marie n Gauthier Posted on Mar 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cost way 6L humidifier keeps shutting off and does not restart. Worked fine for 2 days now when I turn it on it works for 10-15 minutes then shuts off and needs to be manually started again
K McMurdo
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Mar 30, 2019
K McMurdo
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
87356
Points
755
Does it have a sensor that tells it when there is enough humidity in the air? If so you might need to set the sensor higher so it will work longer. Hope it helps?
Michael Youngman
Level 2:
Sergeant:
  • Expert 296 Answers
Michael Youngman
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
180451
Points
743
You need to check to make sure the condenser fan is blowing and that the condenser coil is clean. You absorb heat inside the refrigerator, compress that heat with the compressor, then expel the heat at the condenser (the part of the system that blows hot air). If you can't expel that heat, the unit will lock itself out until you reset it
Testimonial: "What??? It is a small humidifier not a refrigerator! Does not blow warm air, blows cols water mist into the air! Please give helpful info"
5 Related Answers
A
Anonymous
  • Posted on Oct 24, 2008
SOURCE: engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Anonymous
  • 146 Answers
  • Posted on Jan 07, 2009
SOURCE: Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Anonymous
  • 1990 Answers
  • Posted on Jan 23, 2009
SOURCE: All dash lights came on and none of the instrument gages worked.
This Problem is a Direct cause of the Low Temperatures. When it is - whatever the Relays are getting REALLY slow to Respond and Causing all kinds of Problems.
Anonymous
  • Posted on Apr 25, 2009
SOURCE: Car keeps shutting off
After extensive research I have found that in 10 out of ten cases it was the E.C.M or in other words the computer for the vehicle is faulty. You can thank dodge for this problem. What happens is they put a Temperature sensitive device in an area that gets unbelievably hot. Then the Computer overheats and shuts down. In most cases the control panel in the vehicle where the odometer is says "No Bus"
The only way to fix this problem is to put a new computer in. DO NOT buy one from the dealership they are too pricey. Get on off of Ebay. For the extremely mechanical Savy you can do what I did in my durango. I carefully cut the tape away from the main harness then marked everything and cut the harness drilled a hole through my firewall (Just be careful where you drill) fed the harness through and reconnected my computer and mounted it under the dash so when it is extremely hot here in arizona the A/C Keeps the computer cool. With this method I have NEVER had this problem happen to me.
Just don't do this if vehicle is under warranty it will violate the ciditions of the warranty. Hope this helps. I have seen this problem posted to other sites and am just trying to let everyone know what it is and How to fix it.
Anonymous
  • 1776 Answers
  • Posted on Jul 20, 2009
SOURCE: engine shuts off while driving
I would suspect a faulty EGR valve, but is the check engine light on? If it is, take the vehicle to an autoparts store and have them use a scan tool to retrieve the fault code(s) stored in the computer. Most parts stores offer this service free of charge. That will narrow the search for the problem. Sure hope this helped.
MoistAir HD14070. Why does it keep shutting off?
https://www.google.com/search?q=Moist+Air+HD14070.+Why+does+it+keep+shutting+off?&source=lmns&bih=625&biw=1349&hl=en&sa=X&ved=2ahUKEwjN88-lgt_tAhW02nMBHZopByMQ_AUoAHoECAEQAA
Dec 20, 2020 • Humidifiers
1helpful
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 • Humidifiers
I hooked up a honeywell HE220A by-pass humidifier and the water is constantly running with the furnace on or off. I wired it the same way the diagram said using the transformer that plugs into an outlet,...
If you have very old furnace, does it have a blower with a belt. If it does it should only have 2 wires going to blower. If it has 2 you should be able to use the transformer you have plugged into wall and splice into 2 wires going to blower. If you have more than 2 wires to blower, you will need to find out which one is used for heat plus use the white one. If you have a voltage sensor you should be able to find it easily.
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
1helpful
Aprilaire 760 keeps running.
The humidifier should not turn on untill the furnace blower starts. Since the fan stays on. does the solenoid valve also stay on? If they both stay on you probably have a bad humidistat. If only the blower stays on then the circuit bourd in the humidifier is defective.
Good luck
HVAC Teacher
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Furnace blower motor turns on with no flame burning
Hi!!! You might have a bad flame sensor its a single rod located in the burners its white..If the unit runs and then shuts off and on and off.change your flame sensor..Good luckk..
2answers
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Top Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Humidifier Expert? Answer questions, earn points and help others
