Refrigerators Logo
B
BJ Petersen Posted on Mar 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We just got our refrig out of storage and it appears as though the tracks for the freezer drawer (bottom freezer) are sticking from some rust that developed. can we us WD40 or something else
Justjim
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Mar 30, 2019
Justjim
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
13034
Points
54
WD40 is poisonous. The smell will permiate into your food. It also evaporates so any benefit would be short lived. WD40 was never designed as a lubricant and will turn any residual oil or grease to sludge.
Use a silicone lubricant designed for food equipment.
Michael Youngman
Level 2:
Sergeant:
  • Expert 296 Answers
Michael Youngman
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
180361
Points
743
WD-40 is fine. Remember that it's a petroleum based product, so you need to just spray it on the rollers. Use rubbing alcohol to clean up any overspray so you don't contaminate any food that goes in the drawer.
Level 3:
  • Refrigerators Master 19,187 Answers
  • Posted on Mar 29, 2019
Level 3:
Answers
19187
Questions
0
Helped
4341863
Points
82259
WD 40 is good for this but it is not designed for a problem like that. WD means Water Displacer and it works best to lubricate things that are subject to wet conditions before damage has occurred.
5 Related Answers
Anonymous
  • 770 Answers
  • Posted on Jan 24, 2008
SOURCE: Maytag Frenchdoor w/freezer drawer - drawer sticks
you will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 20, 2008
SOURCE: Storage drawer - design flaw?
yea find it hard to believe that a product would be built this way!!, without looking at it would imagine that the tracks going back on both sides are too close together, which usually happens when the unit is mishandled upon delivery, a quick call to an authorized servicer will correct problem( it is a warr issue any way, and from the sound of it hell have a lot of warr work in your development
Anonymous
  • Posted on Nov 24, 2008
SOURCE: JCD2389DES Water Leak Problem
Once I saw that the drain tube went up over the coil before draining into the evaporator pan I decided to buy a small piece of flexible plastic tubing and re-route the tube so the water could freely flow down hill. It's been over two months with no additional problems. I can assume that since the water drains freely it doesn't stay trapped in the elbow freeze and the cause the collector tray to ultimately overflow.
Anonymous
  • Posted on Dec 22, 2008
SOURCE: On TCD18PAD BWW refrig with
You have a clogged defrost drain tube. On the back of the refrigerator in the center, about two feet above the floor, is a 7 inch by 7 inch square steel cover held on by four screws, one at each corner. The defrost drain tube emerges from the bottom of this cover and terminates loose in the drain pan below the refrigerator. Remove the cover. Underneath is the plastic defrost drain tube fixture, which is held by two screws. Remove the screws and take off the drain tube fixture. This fixtue is clogged. Run hot water and dish detergent through it and blow through it at the big end to remove the clog. Reassemble. That's it. You don't have to take the refrigerator apart. One caution. When the refrigerator has a clogged drain tube, the defrost water will back up and freeze around it. So you may need to empty your freezer and unplug the refrigerator for eight hours or so first before you perform this procedure to allow all the ice around the clogged drain fixture to melt.
Anonymous
  • 1142 Answers
  • Posted on Mar 24, 2009
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Ad
    Kitchen aid French door refrigerator has freezer drawer at bottom that doesn't open after being in storage for over a year
    Use a hair dryer to heat it and try spraying some silicone spray such as WD 40 around the tracks. Something has dried and caused it to stick. Try removing the top of the drawer from the frig. It you can, it will be a lot easier to un-stick
    The bottom freezer drawer is not closing so the freezer is getting an ice build up
    It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
    1helpful
    I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
    Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
    2answers
    Items in refrig are freezing when they're not supposed to.
    thermostat has failed i'd say..its not turning off at the requested temp.
    1helpful
    M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
    That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
    PART NUMBER AND MODEL SEARCH FEATURE
    Food is freezing in the bottom drawer of my Maytag side by side
    check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
    8helpful
    2answers
    Amana bottom freezer model #BX21TW purchased in 1996
    this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
    Subzero bottom freezer drawer is freezing shut.
    Silicone bath/shower sealant should work, the one that smells like vinegar. Also known as RTV.
    Just make sure the area is dry, clean and free of old caulk.
    It'll need to be at room temperature to set properly for a few hours.
    I have used this sealant on things before that went as low as
    -50C. Preperation is the key though.
    4answers
    Sub-Zero 550 water leak and freezing
    Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
    Top Refrigerators Experts
    ZJ Limited
    ZJ Limited
    john h
